4r100 vs. 4r75 transmissions
I am replacing the 5.4L 2-valve engine in my '99 Super Duty 4x4 with a 5.4L 3-valve engine from an '06 E-350. I'll have the entire wiring harness, including every connector, from the van. My panic is whether the 4R100 trans in the pickup will have an issue with the programming of the 3V PCM from the '06 (which had a 4R75W trans - I also have that), or whether they are separately controlled. If the pickup was a 2-by, I wouldn't care about using the 4R75W and wire it all up using the van harness. But the 4R100 is almost 6 inches longer than the 4R75W and I have found no means of adapting the transfer case.
Wow, I just learned something today.
DavidB, in the SD trucks, they have been stuffing the 5R110 behind the 5.4 since 2005. So, it would logically follow that the same transmission in the SD trucks would be used in the SD vans.
But it's not.
As per THIS DOC the 5R110(TorqShift) was only put behind the diesel engine, all others were the 4R75E.
Very strange...
But it's not.
Very strange...
But it's not.
Very strange...
But it's not.
Very strange...
You may also want to start a thread here as well:
https://www.ford-trucks.com/forums/forum170/
^ ^ ^This is the 1994.5-1997 7.3 Powerstroke Diesel forum. Lots of knowledgeable folks down there as well that can point you in the right direction.
I'm not much of a transmission guy so I can't help you out much there but others in these forums can and will gladly help out. Best of luck with it and again, Welcome to FTE!
My truck is a 7.3 International Diesel. 1995 F350 Crew Cab SD. Just got it today & it needs a few things. Couple of window motors, possibly an alignment. Just noticed driving it home the tranny shifts hard & the steering seems loose. Wondering if a trip to the tranny shop is needed or if a pan service will help it.
Brad
