Front axle toast ! 97 F250 Crew 4wd 7.3l
#31
"Looking to buy this.
Dana 60 high pinio front axle and matching rear axle. 4.11 ratio. Out of a 94 f350. You can have axles, springs, and drivelines. Front has steering and tie rod attatched. All brake lines are still on both. If you text me
with your number I can send pics. All for $1300.
Also have a zf 5 speed tranny with transfer case($250). 16" Aluminum wheels($125). Rack it lumber rack($150). Warn winch bumper($200)
Since sellers says its high pinion should it have a better turning radius?
Do I confirm it has
1 Track bar mount and a track bar
2 F350 Springs
3 Driver side U-bolt plate.
4 Steering linkage .
5 Pitman arm
6 Front driveshaft
7 Front brake hoses
8 F350(4") rear block
Do I confirm it has
2 F350 Springs
5 Pitman arm
6 Front driveshaft
7 Front brake hoses
#33
Do I confirm it has
2 F350 Springs
5 Pitman arm
6 Front driveshaft
7 Front brake hoses
Do I confirm it has
2 F350 Springs
5 Pitman arm
6 Front driveshaft
7 Front brake hoses
looks about rite.... A bit pricy. High pinion just means that the pinion is above the center line of the ring gear (good for a front axle). Your turning radius will not be better due to the limitation of the leaf springs.
richard
#34
This axle is 8 hour drive each way.
Including all the "extra" items what is a fair price?
Would be will to buy any other items listed to sweeten the deal. Probably get the wheels.
Funny I am looking at buying a Jeep in Pheonix.
#35
#36
#37
Richard
#38
Yards here in Los Angeles want $400 PER AXLE BARE.
The issue here is a core charge is $100 for scrap and want they don't sell here can easily fill a 40 foot container and ship overseas for much more money.
Thats is how lots of the construction equipment left California.
#39
Here is a pic of a axle. Told it is a F350 out of a 1994 with 4.10
How do I confirm?
http://s407.beta.photobucket.com/user/roachjob/media/axle_F350_94_zps6e440f32.png.html"
Does this look like the correct axle?
How do I confirm?
#43
Just make sure you get the bracket that was bolted to the frame for track bar to hook to.It looks like in the pic it is not on it.Hopefully he has a box of all the stuff like that even if you replace hardware .
If the axles have their tags have him send close ups and you be able to verify ratio also.thats a long drive.but worth it!
#44
The seller is providing
All parts on the axles as pictured.
4 Original wheels
Tranny and xfer case
F350 Springs front and rear
Steering linkage .
Pitman arm
Front driveshaft
F350(4") rear block riser
But not the brake hoses since they were cut to remove axles.
All for $1800 ... what do you think?
Does the steering linkage appear bent or is it "factory" bent?
#45
I thinks it atleast $600 to high....The axles are the right ones, I can't say for sure if the steering linkage is bent or not, but its cheap to get a new one.
unless he Guarantees the trans is good, which is almost impossible, it's worth $100. Same with the t-case so really the only thing of value to you is the front axle and suspention parts.
Offer him $1200 cash.
Diesel Rod
Diesel Rod
