8.8 Rear 3.55 vs 4.10 ??
I have a 1995 F-150 with a 5spd and in 5th gear at 60 mph I'm just over 2k on my tach. Should I change my rear gears to 4.10 to get my RPM's down? Or would this make much change? Or would there be a downfall elsewhere?
I believe I have 3.55's in there now.
Checking Summit I see other gears such as 3.73, 3.90, 4.30 and 4.56's
Cheers
Cheers
on
With an I6 under the hood 3.55 gears is just about perfect for overall performance and towing, if you want to improve milage some just fit larger tires since the stockers look goofy anyway, but remember to recalibrate the speedo or you won't see the milage gains and may even see losses. 32's fit without any mods while 33's may require a levelling kit.
I have 31 inch tires and factory 4.10 and I also tach at 2150RPM @60 MPH.
I test drove 3.55 and my 4.10 geared F150s with the 5.0 when I was looking to buy several years ago------- and there is just no comparison between the two. 4.10s are great for pulling and acceleration!
There is about a 200 RPM difference at 60 MPH between 3.55 and 4.10 gears in overdrive. 4.10 makes the first gear of the M5R2 more of a granny first gear. I am able to turn thur city intersections in fourth gear with the truck unloaded.
You will be able to reprogram the speedometer yourself electronically without expense. See this:https://www.ford-trucks.com/article/...ND_BRONCO.html This works very nice--I did it when I changed from 235/75 x 15 to my 31 inch high tires.
But you will only need to change the speedo calibration if you change the height of the tires-changing the axle ratio will not change the speedo reading. Because the VSS is located at the ring gear at the axle--not the tranny.
on
Just to be clear you would have to go to a numerically lower gear(3.31, 3.08) to achieve a reduction in rpms, that could easily cost $500-800 per axle which will take a long time to recover from fuel savings.. if in fact you save gas at all, that's not a certainty but what is certain is that the truck will lose towing capacity.
stevieray
07-24-2001 11:31 AM
