Which dash light is this?
Old Jan 3, 2013 | 12:50 PM
mozzles's Avatar
mozzles
I didn't snap a photo but this morning one of my dash lights stayed on after I started it, most of the lights don't have the plastic insert so it's just a light. It's between the right turn signal light and the brights. Also, it was like 0 degrees this morning and I wasn't using any fuel additives so that might have something to do with it. Never seen this light come on before so that's what I'm thinking.
And while I've got you here, what's a good anti-gel to use in winter? I've never had to get any before so I have no idea. Hopefully I didn't do any damage running it for a few minutes this morning without it, seemed like it was idling fine just smoking a lot.
Zac
Old Jan 3, 2013 | 04:26 PM
madpogue's Avatar
madpogue
Um, what year truck? This section covers THREE generations of truck, with different dash clusters. Do you have the owner's manual? They're crazy cheap on eBay. If it's an '83-'86 truck, and if I'm remembering right, that's the 4x4 indicator. If it's a '92-'94, all the diesel-specific lights (WTS, WIF, Filter) are in a separate panel, so it wouldn't be any of them. If it's an '87-'91 I can't help you.....
Anti-gel, I usu. end up getting Power Service white-bottle, just because it's what goes on sale most often at the local man-mall (Farm & Fleet). And make sure you buy good quality winterized fuel from a reputable station that sells a lot of diesel (faster turnover).
Old Jan 3, 2013 | 04:36 PM
mozzles's Avatar
mozzles
I figured people would just look at my sig like usual, I went into detail in it. Otherwise I'd be posting it in every thread I make.
It's not the 4x4 light, I know that one has the cover over the bulb. Not sure what it would be. Thanks for the tip on getting an owners manual, planned on doing it eventually.
Old Jan 3, 2013 | 05:52 PM
Wild Ziggy's Avatar
Wild Ziggy
Did it go out after a few seconds? Could be the check engine light due to low oil pressure
Old Jan 3, 2013 | 08:35 PM
madpogue's Avatar
madpogue
BRAKE (!) failure warning light. Comes on with the parking brake, and also (more importantly) if there's a hydraulic failure with the main brakes. Goes on at engine start as a bulb check. If it's still on, and you're not using the parking brake, check the level in the master cylinder and inspect the lines, calipers and wheel cylinders for leaks.
Old Jan 3, 2013 | 09:45 PM
Onus's Avatar
Onus
The light can also be triggered via the low vacuum switch.
I actually wanted to see if the switch actually worked and drained my vacuum by pump the pedal and ton at idle. Brake light did come on.
Old Jan 3, 2013 | 10:51 PM
mozzles's Avatar
mozzles
My brake booster isn't working, could that have something to do with it? It's never came on before today that I noticed, so I figured it was temperature related.
Old Jan 4, 2013 | 12:02 AM
madpogue's Avatar
madpogue
Could be. I haven't tested it or checked the FSM to see if it's true on the '80s vintage trucks, but on the later ones (PSDs), that light is also tied to the vacuum pump. There's a sensor on the vacuum distributor block; if it senses no or insufficient vacuum, it sets the BRAKE (!) light. So check your vacuum pump; it may be the cause of your inop power brakes.
Old Jan 4, 2013 | 06:50 AM
Otahyoni's Avatar
Otahyoni
There should be a separate light down by the 'Wait To Start' light for the low vacuum warning.
Everyone else is right though, that light is the BRAKE (!) warning lamp, also used with the parking brake. It's supposed to come on while the key is in start or if there is a leak, but mine very rarely has...
Old Jan 4, 2013 | 07:58 AM
madpogue's Avatar
madpogue
No WTS light on the '85. The only lights down there are GLOW PLUG, WATER IN FUEL and ENGINE TEMP. Is '86 that different?
Old Jan 4, 2013 | 10:34 AM
mozzles's Avatar
mozzles
I can't remember right now but come to think of it, the Water In Fuel light you're talking about did come on momentarily. I think maybe everything was just a little screwy since it was zero degrees outside.
Old Jan 4, 2013 | 10:50 AM
madpogue's Avatar
madpogue
Yuh, this is the time of year when even the electrons are shivering....
Old Jan 4, 2013 | 05:58 PM
tecgod13's Avatar
tecgod13
For the earlier 80's trucks, the GLOW PLUG light I'm pretty sure was renamed WAIT TO START when they changed the dash. My interpretation was to make the truck more idiot proof as most people wouldn't know what glow plugs are, but might pay attention to something telling them to WAIT!!! before starting.
Other than that, I'm not sure what the earlier dashes look like, sorry.
Waltdog
May 20, 2010 03:17 PM
Wizard1946
Nov 23, 2008 10:09 PM
AirTran
2004 - 2008 F150
Feb 13, 2006 05:56 PM
jcs1966
Jun 1, 2005 08:43 AM
isaz
Dec 15, 2003 02:28 PM
