100hp Injectors
100hp Injectors
hi im looking to install 100hp injectors in my 2003 ford f250 7.3l and was wondering if this is a bad idea or not? i have a ts proformance 6 position chip with stock, lope, 80hp daily driver, 100hp race and 120 race. also i have a S&B auto cold air intake, with an exhaust with a 3in down pipe into 4in then into 6in stacks... i heard if you get to much HP it is bad for the connecting rods? is this true or can i get away with 100HP injectors??
ok, they are the 100hp nozzles...here is the link for them so you can see what im looking to get...
8 New Alliant Injectors w 100HP Nozzles Ford Powerstroke 7 3L Diesel Truck 99 03 | eBay
there is Riffraff, Full Force, Beans, Farmers......Contact Clay at Riffraff or Matt @ Full Force (just google them)...Keep in mind, you will probally have to sent the chip back for updated tunes for your injectors...and yess, the link is way to high and siund like split shots (factory injectors)
the price is with a 1200$ core charge so subtract 1200 hundred from that. but what is the site i can find them on? i need to get them and i dont really want to go back to stock so if i can get away with any aftermarket without causing any damage to my motor i want to get them...
Riffraff Diesel Performance Parts: Diesel fuel injectors | Ford Powerstroke fuel injectors | 7.3L Fuel Injector - Full Force Diesel / Casserly
Take a look at Swamps diesel. They are the ONLY company that's builds their own injectors and also does their own tuning. I like the idea of no finger pointing between the injector suplyer and the tuning company. Swamps may not be the cheapest but, They have the best warranty you will find.
Before you enter your card number into a field for ordereing, consider this:
- Is this your daily driver? Getting itchy for megapower reduces the reliability. Can you afford the down time?
- The truck loses its road manners at certain power levels, it's then a ricer-eating beast.
- You have all the air in and out mods to prevent making a coal factory with burning EGTs? Including the CAC boots and intake plenum insert... or billet plenum?
- Your transmission is beefed up?
- What are your plans for the fuel pump? Stock can barely handle AC 160/100s.
- Are you financially prepared to fix all the weak links that more power exposes?
- Are you willing to take a hard look at what your goal is, what your rescources are, and consult with those who have already rolled in this field of bear traps? I added 100HP... but the injectors were not the biggest expense: The transmission was. Then the air system. Then the exhaust system. Then the gauges, tunes, tuner, and monitoring software. The injectors fell pretty far down this list.
I ordered the Swamps 200/30 injectors (stage 2 aprox 450 horse) and I have a 38R turbo and I was told I won't need anything else other than my regulated return. You may be better off with the 175/146 injectors (stage 1) which I believe will get you a bit under 400 horse if I remember correctly. There are also 160/80 that many people like. So many choices.
