1974 Black F100 Custom 2WD
Year: 1974
Make: Ford
Price: $5500
Mileage: 126000
Color: Black
Private or Dealer Listing: Private Listing
Location (State): CO
Transmission: Manual
Drivetrain: Rear Wheel Drive
Color: Gray
Engine: 390-4V
DRIVETRAIN:
390 Bored .060 over with less than 10,000 miles on rebuild
Ported/ Polished heads with 2.09/1.66 stainless valves, Performance 3 angle valve job
Edelbrock Streetmaster Intake with Performer Carb
Crane Solid Lifter camshaft
Erson rocker arms
High volume oil pump with windage tray
Edelbrock aluminum high volume water pump
Ram air set-up
Ford T19 medium ratio manual transmission (5:1 1st gear)
New clutch and flywheel
Ford 9 inch rear with Detroit Locker
3.00 ratio (3.50 gear-set available)
Dyomax headers
3" dual exhaust
Lincoln Mark VIII electric fan
Ford 130 amp 3G alternator
SUSPENSION/BRAKES:
4 wheel disk brakes
Front and rear aftermarket sway-bars
Monroe Sensa-Trac shocks
TIRES/WHEELS:
Mid 90s Ford chrome wheels with BFG 31" TA/KO tires. 25% tread
Wheel Vintiques 15X6 and 15X8 steel wheels with BFG radial TA tires. Brand New, 235 and 275 series front and rear.
INTERIOR:
Refinished bench seat
Vinyl floor mat
Aftermarket digital temp and volt gauge
New headliner
Pristine dash pad, no cracks!
Factory cluster un-molested
Delay wipers
EXTERIOR:
Recent black paint. Originally red with white top.
NO RUST
Excellent chrome and trim. Fabulous grille shell and inserts
Hella H4 headlight conversion
Heavy Duty Headlight relay
Bed is unfinished, was pondering spray-in bedliner or plastic. No major dents or damage on bed floor.
Have been using a 67-72 tailgate, also unfinished
Have rear roll-pan if desired.
Windshield excellent.
Decent 3 foot quality bodywork, not car show quality, but easily turns heads. No dents and no rust.
I am very proud of the truck and it has never let me down, but I just don't have the time to enjoy it like I used to and would hate to just have it sit around in the garage. It needs to be driven.
After that long description I am sure I have left a few things out. I have YOUTUBE videos under user BULLITT406. The youtube videos, however, show when the truck still had the dual quad 428. The 390 I installed is just as healthy.
YouTube - Ford 428 Exhaust
Thanks,
Josh
truck sold?
Josh,
Has your truck been sold?
If yes, then congrats and disregard the rest of this message.
If no, is the shifter on the column or the floor?
Does it have electronic ignition? Factory installed?
Power steering? Factory installed?
Disc brakes? Factory installed?
Your time is appreciated.
-Dave
-Dave
1976f150dude
21
03-27-2024 09:15 PM
WhitefishBoy64
25
12-10-2013 02:10 AM
76f350spercamprspeal
Vehicles for Sale
04-10-2013 03:13 PM
