My truck is a 1977 F100 Shortbed and currently has a Dana 44 in it. I want to switch over to a 9". Will the driveshaft work without having to change yokes or shorten/lengthen the shaft? Is it a direct swap?
Good luck at the parts counter asking for a combination ujoint lol!! (If youll even need one) They have them but both times I have asked its pretty much left them confused and me digging through the stash in the back
What about the length from the center line of the axle to the center of the yoke?
Are they the same?
This is just an educated guess but I think the Dana driveshaft will be about 2" shorter than the Ford.
I'm taking a guess on the specs of your truck. I used '77 shortbed 2WD w/ 302 automatic. The parts catalog shows the Dana driveshaft to be 53 9/16" long and the Ford driveshaft for the same specs is 55 17/32".
That's a 1 31/32" difference in length. The catalog also shows that the both shafts use the same u-joints and slip yoke.
No help to the OP, but I have the same thing in my '78. Love the 2.72 gear for mpg. Haven't driven enough since the intake/carb swap, but I used to get about 20 mpg. I also have a '77 parts truck with the 9", not sure of the gears, but have thought about keeping the axle around as a spare. I assumed it was a direct swap.
