When I leave a stop sign or light it sounds as tho the rear end is going to stay there. Had everything replaced once when limited slip plates went out. Since then the clunking niose has always been there. Its been 3 years ago and it still drives fine with no vibration. Is this normal for the Bronc ? little concerned if I should take to shop again. Open for suggestions! Thanks
Thanks to the imput from all you ford owners who takes the time to reply to a thread, I thank You! Greaseing the slip joint got rid of clunking noise.... sure saved me a trip to the local ford garage!
I have a clunking noise coming from somewhere in the front of my 93 Bronco. Every morning when i leave the house, I drive down the road, and the first time i apply the brakes, i hear and feel a clunk. It won't do it again until i turn the truck off and start driving again when i hit the brakes for the first time. Anyone know what that might be???
