RRE V 2013
I'll gladly scan the article in the magazine if you wish.
They are morons when it comes to powerstrokes.
Well, the guys who usually write the articles are.
This one I'm speaking of is really funny.
They talk about the different injection systems in the trucks and completely screw up the powerstroke info.
So the next issue they correct it only to screw it up yet again.
Really shows you how much they think of fords.
Specially since a majority of the magazines are dodge this chevy that.
I just stopped bothering to buy them.
Their performance upgrade suggestions on powerstrokes were crap and un-educated.
They just spend to much time trying to make our trucks look like crap and that you cannot have a nice performing truck unless you replace everything but the block.
Now moving on to what your saying about swash plates.
To MFG pumps that far out of tolerance and spec would mean that half of our trucks would just be absolute piles of crap.
You mean to tell me that with the MFG processes in the last 20 *explicit deleted* years that we cannot manufacture within close tolerances of 15°??? or 17°??????
GTFO
The pumps were changed to ramp up oil pressure and flow for the larger injectors of the super duty trucks.
It wasn't a "manufacturing mistake in tolerances."
Yeah, let's just make **** up!
Lets think about this really simple, cause this **** is really really just rocket science.
It's a round piece of metal with an ANGLE cut on it.
That's it.
a round piece of metal with an angle cut on it.
That's it, nothing more.
You cannot have that much of a variance in a machining process to just claim they were "way out of tolerance."
Even if you cut the efffing things with a band saw you would not be that far out of spec!
Yes, the T500 is a 17* pump that has been gone over and is suppose to be a little better then a 17*. How much, I don't know, Talyn probably knows because he visited Joey and got a 'tour'.
GTFO
That's it.
It's just a rotary style pump.
Your stroking the cylinders more with the 17, and there are gains.
Volume is king. Not PSI.
The 15 to 17 change though will net you more oil per stroke, which is more volume, thus letting the pump work less hard creating more PSI when demand is higher due to more volume.
Joey's pump is going to modify the journal bearing pumps into a ball bearing pump as well.
Which is well worth the upgrade alone.
Cause if your in a tent, your gonna be camping next to my truck. :P
Cause I sleep in that ****.
....premiums are out of my budjet though...maybe I need to just leave it alone until I can do premiums.
