Cranks but will not start 2001 F-350 7.3 psd
#31
#32
LPOP
If you add about a pint to the HPOP reservoir, put the plug back in and see if it starts for a few seconds. You dont want to add more than a pint, it will just overflow and run down into the oil pan. If it starts, runs for a few seconds and dies, most likely the LPOP.
IPR or CPS can also cause a no start.
BBD
Last edited by Big Black Dually; 12-22-2016 at 09:27 AM. Reason: Left something out
#33
I have a 2001 f350 psd crunk up in the morning after warming up started stumbling cut it off and went to crank back up had no wts light and would crank but no start. check all fuses and relays none blown. some times wts light will come on but go back off. checked icp sensor and had oil passing thru sensor and replaced. still no wts light ohm glow plugs and are ok and checked glow plug relay and ok. finally had wts light and crunk up and stumbling bad and when barley touch throttle rpms shoot up to 2500 blow black smoke. anyone had this problem let me know
rlpatte
02-01-2022 05:10 PM
Northernroots122
27
01-02-2019 09:52 AM
2001 f350 7.3 cranks but wont start fuel pumps work ipr good all fuses good icp is next to be change
Hinemanz
37
07-18-2017 07:03 PM
Ol Country Boy
07-26-2013 09:59 AM
