7.3 Block Heater
http://www.phillipsandtemro.com/user...CATALOG(1).pdf
The zerostart heaters are the OEM supplier. You can get a heater in either 1000w (#3500043) or 1500w (#8602611) varieties, you just have to use the Ford 7.3 engine numbers under agricultural engines. The 1000w is standard size heater. The standard cord is #3600008, though other cords may work.
