cracked exhaust manifold
Old 12-26-2012, 09:54 PM
garmar60's Avatar
garmar60
garmar60 is offline
need some help from the experts, We just installed a reuild long bolck in a 06 f150. its the 5.4L. used new exhaust manifold hardware and gaskets, torqued the studs and nuts per the specs. runs good, no codes but we have a slight surge, about 25-30 rpm, most noticeable at about 1700 rpm. with the code scancer in it we see a variation in the rpm, the short term fuel trim and the o2 sensor values. we noticed a crack in the right side exhaust manifold, near the rear, on the top. would this cause the surge problem. how can this be fixed. i have a mig welded but dont think it will work on cast. can it be brazed or is there some other way to fix.
We are open to any ideas.
thansk
gary
Old 12-27-2012, 11:48 PM
IndyDragon's Avatar
IndyDragon
IndyDragon is offline
The only way to weld cast and get a really good bond is to stick weld it with nickel rod. You need to clean the area to be welded thoroughly first and pre heat it with a torch so that you get a good solid weld.
3Lstroker
1997 - 2003 F150
11-14-2011 09:41 AM
thundersnow70
16
11-13-2010 09:35 PM
quentinorciuch
07-19-2007 12:50 AM
351ballsofford
05-25-2004 07:30 AM
shawn h
11-24-2003 06:00 PM
Quick Reply: cracked exhaust manifold
