94 f350 460 oil pump install
Old 12-20-2012, 05:11 PM
dunecj2a's Avatar
dunecj2a
dunecj2a is offline
I am replacing my oil pump and I wanted to make sure I installed my drive shaft correctly. I jacked up my motor and removed the pan. When I put the new pump and shaft back on I put the shaft in the pump and bolted it back on. I had to turn the shaft a little to seat in the block. It was binding up a little bit as I was tightening the 2 bolts that hold the pump on the block. I hope that the shaft is seated properly in the block since I had no way to see where to put it. I used the pump to guide it up into the block. Does this method sound ok?.. Thanks
Old 12-20-2012, 05:50 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
There should of been NO BINDING when tightening the oil pump bolts
F150_Oz
10-11-2010 08:45 PM
f250red
10-02-2009 06:18 AM
z1121jack
04-15-2009 06:17 AM
maddmaxx29
11-19-2006 08:04 PM
78ford351m
07-07-2006 01:46 PM
Quick Reply: 94 f350 460 oil pump install
