C6 Transmission Fluid Change - Ford Truck Enthusiasts Forums
Old 11-18-2014, 11:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
Print Wikipost
Old 12-20-2012, 06:22 AM
Corkwheats
Corkwheats is offline
Corkwheats is starting off with a positive reputation.
Friends,
I'm planning on doing a transmission fluid change on my 71 Ranger w/C6. The one Quikie Lube place in town won't do it, because they feel the F Type fluid would screw up their machine (by the way - is Type FA actually the same thing?). So, I plan on doing it myself, and wanna do it right using the Type F.
I spoke to the head honcho at the Quikie Lube place, and he said that even if I pulled the pan, I'd only get out about 2 quarts of transmission fluid out. Then, he recommended something I've never heard of.....
He said to do somewhat of a "power flush" on your own, take off one of the transmission cooling lines that go up to the radiator (gotta pick the right one). Then start the engine. It will pump out the transmission fluid, and in the meantime, you can be pouring it back in with a long spout through where the dipstick is. Thereby, you are sorta doing your own power flush of the system.
No need to pull the pan, and replace the gasket & filter. He said that the filter really doesn't need replacing, anyway.
Anybody else ever heard of this, or tried it?
Thanks,
Bob
Old 12-20-2012, 09:42 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Go to a parts store, buy the filter, gasket and 3 quarts of Type F ATF and do it yourself.
IDIOT at quikie lube doesn't know what the hell he's talking about.
Old 12-20-2012, 11:49 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
You will need more than just 3 qts to truly change the fluid. Ford thoughtfully put a drain plug in the convertor, pulling that and dropping the pan will get almost all the old fluid out at once.
This method requires 8-12 qts, depending on exact trans configuration.
Old 12-20-2012, 12:07 PM
NumberDummy
C6: If replacing just the filter, approx. 3 quarts of ATF will be required, because that amount will drain from the pan.
If changing all the ATF including the torque converter, approx. 13 quarts of ATF will be required.
Old 12-20-2012, 02:15 PM
Corkwheats
Thanks Guys,
This is one that I have been definitely planning on doing myself. I already priced the filter & gasket, and it's really cheap. I'll have to look into the deal about draining the thing completely - I think I'd rather do that, and just start out with all new 12.75 quarts of Type F in there. This truck has been around awhile - and the first thing I did with it was change the oil/oil filter. Knowing that the transmission has been completely serviced will make me feel better.
Is there a schematic, or tech tip that shows how to get to the drain plug on the converter? Or, can somebody just point me in the right direction? I ought to be able to find a drain plug if I look hard enough.
Lastly, is Type F the same regardless of where it comes from. Advance auto Parts sells it for $4.99. WalMart has it for $3.58. Is it most likely the same quality?
Thanks!
Bob
Old 12-20-2012, 08:01 PM
carchub's Avatar
carchub
carchub is offline
carchub is starting off with a positive reputation.
IMO, buying fluids/oils from WalMart is kind of iffy, unless they have a product from a company that I know I can trust/something I've used often in the past. If it's some knock-off, cheapo looking crap, I wouldn't use it. I've never used anything cheap like that though, so I don't know if it's the same quality.
Old 12-20-2012, 10:02 PM
Old Blue 67
Old Blue 67 is offline
Old Blue 67 is starting off with a positive reputation.
To drain the torque convertor simply remove the dust cover from the bottom of the bell housing, then have a friend bump the starter over till you see a drain plug (not while you're under there of course).Be sure to bump it till it's at the very bottom to get all the fluid out.
If you can't get a helper, simply rotate the crankshaft with a ratchet and socket till you get the plug at the six o'clock position.I think the plug is 3/8s but it's been a while so don't hold me to it. If at all possible, remove the pan and convertor plug and let them drain over night to get as much as possible to drain out. Good Luck,Calvin
Old 12-20-2012, 10:23 PM
Corkwheats
Thank you, Calvin! Great tip - I'm gonna do exactly that!
Bob
Old 12-22-2012, 08:53 PM
1972-34ton
1972-34ton is offline
1972-34ton is gaining momentum as a positive member of FTE.
Wink F and FA Transmission Fluid are different
Type F is for the old bands, with asbestos in them. Newer bands don't have the same composition. Ask the rebuilder to be sure.
-If I knew anything, I'd have a real job-
Old 12-22-2012, 11:04 PM
instig8r63
instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.instig8r63 is gaining momentum as a positive member of FTE.
Use Type F.
Dexron and Mercon have friction modifiers that make the fluid less "grippy" for softer shifts.
Old 12-23-2012, 02:15 AM
NumberDummy
Originally Posted by instig8r63 View Post
Use Type F.
1964/76 C4 & 1966/76 C6 = Type F (C1AZ-19582-A) / 1977 and later: Mercon (XT-2 QDX).
Old 12-23-2012, 07:56 AM
Alex from GA
Alex from GA is offline
Alex from GA is starting off with a positive reputation.
Advance matches prices so get the Walmart price and bring it to Advance. You can print out the price from the web site. I assume they're both the store brands, Super Tech and Advance brand. I use the Walmart brand oils in all my stuff for much less than others, including 2 stroke oil in my boats, and never had an oil related failure.
Old 06-20-2018, 09:58 AM
flappy188's Avatar
flappy188
flappy188 is offline
flappy188 is starting off with a positive reputation.
can any one tell me where to add fluid to the trans at? is it through the dipstick?? mine is also a c6 trans and its low on fluid!!!
Old 06-20-2018, 10:22 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
MIKES 68 F100 has a very good reputation on FTE.MIKES 68 F100 has a very good reputation on FTE.MIKES 68 F100 has a very good reputation on FTE.
I have done the DIY power flush on my Daily driver Kia . Never thought about doing it on the truck as it has a removable Pan .
to tell pressure line , when cold start engine . touch the trans lines going to radiator the one that gets hot first is the line you want . i marked mine with a stripe of paint for future reference .
You will need a big pan (tall ) as fluid comes pretty quick and have someone sit in car ready to turn off as soon as fluid stops flowing .
I then drop pan to get rest of fluid out (plug on Kia it has no pan)
Old 06-20-2018, 10:30 AM
Salty Dog's Avatar
Salty Dog
Salty Dog is offline
Salty Dog has a great reputation on FTE.Salty Dog has a great reputation on FTE.Salty Dog has a great reputation on FTE.Salty Dog has a great reputation on FTE.
Yes the dipstick
Quick Reply: C6 Transmission Fluid Change
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
