The lever/switch on the column - ran outside to check nothing appears on the dash and no noise when I hit blinkers - guess I need to pull panel off and find another switch under the column?
Not just yet. I don't know if the fuse for the hazards is different than the turn signal. Let me check on my truck. I assume you had the ignition key turned on, right? Not to sound insulting, just checking. I make mistakes like that myself.
Umm, regarding replacing the flasher unit! It's under the dash to the right of the steering column. The flasher unit and the blower relay are in the same block/holder. Did you perhaps replace the blower relay instead of the flasher unit?
