Battery Drain Help Needed
Old Dec 17, 2012 | 08:28 PM
Twim's Avatar
Twim
So in my quest to track down what is draining my batteries, I discovered that there is a significant draw coming for the two wires connected to the solenoid on the fender going to the starter. The way I discovered that was by having a test light inline from the positive cable to positive terminal, I started pulling fuses but the light was still glowing and when I finally disconnected the cables going to the solenoid, the light stopped glowing. What is the problem, the starter or the solenoid? FYI, the starter is about 6 months old, it is a wannabe Donzo.
Old Dec 17, 2012 | 08:58 PM
F350-6's Avatar
F350-6
Which terminal on the solenoid? One of the large terminals is connected to the battery so it's always hot. Were you testing the outgoing large post, or one of the small ones?
Old Dec 17, 2012 | 09:35 PM
Twim's Avatar
Twim
Sorry, I meant to say, With the test light inline between the positive cable going to the battery and positive battery post, I removed the two nuts that hold the cable to the solenoid and noticed the test light stop glowing.
Old Dec 26, 2012 | 08:55 PM
Twim's Avatar
Twim
Anymore input? Any is appreciated!
Old Dec 27, 2012 | 09:00 AM
nlemerise's Avatar
nlemerise
To give you an idea as to what might be drawing the electricity, perhaps measure the amperage going through the wires. The amperage draw ought to give you a hint as to what is making the draw. Testing with the light lets you know that there is current flowing but gives no info as to how much.
Here is a diagram of the starter circuit...
IF this diagram is complete, it would seem that there aren't very many components that could have an internal failure causing a draw on the batteries.
Old Dec 27, 2012 | 01:51 PM
Twim's Avatar
Twim
It appears that the draw is coming from fuse#22 instument panel junction box, now what?
Old Dec 27, 2012 | 02:11 PM
nlemerise's Avatar
nlemerise
What year is your truck an how do you know "It appears that the draw is coming from fuse#22 instument panel junction box..."?
Old Dec 27, 2012 | 02:49 PM
Twim's Avatar
Twim
It's a 99. With my meter inline and the truck in sleep mode, I see .19A. When I pull the 22 fuse, it goes to .02A.
Old Dec 27, 2012 | 03:22 PM
nlemerise's Avatar
nlemerise
The #22 fuse under the dash on a 1999 protects the following:
air bag module
passenger air bag activation switch
blow motor relay coil
I just don't see how any of these are related to the starter relay...
forango
24
Apr 12, 2018 02:34 PM
jerryst
Jan 22, 2016 08:12 PM
73FordF100
Apr 3, 2010 08:23 AM
burninrubber2416
Oct 5, 2008 12:43 AM
saltydog73
Dec 31, 2006 12:42 PM
