Put new GPR on from Vatozone and it Buzzes?
Remove and bench test it. 12 volts on one small terminal and ground on the other small terminal. Polarity doesn't matter when removed. If it does the same thing it is bad. It can be tested while installed but you must remove the wires from the small terminals so you don't send any battery or ground back toward the PCM. Sounds like a bad relay so you might as well remove it for testing.
Mike Stoddard
02-19-2017 09:20 AM
Tugly
13
11-30-2015 08:42 AM
powerstroker100
18
09-24-2011 11:29 AM
