6.0 Oil Cooler Replacement - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 12-18-2012, 12:34 PM
MauleOne
MauleOne is offline
MauleOne is starting off with a positive reputation.
6.0 Oil Coler
Thanks, I have seen the BPD oil cooler and am glad to hear that it isn't required unless the truck has a delta on the oil/coolant temperature.
I will be buying a truck after this work shift (Jan 12th) and will pass on particulars.
Old 12-19-2012, 08:25 AM
kidoo
kidoo is offline
kidoo is gaining momentum as a positive member of FTE.
Once you have a kleen system, I think a fliter and ELC Cat 1 is number one in prevention of a clogging oil cooler. I just replaced the coolant filter yesterday after around 15,000 miles. All there was in there was about 1/8, may be 1/4 teaspoon of debris.
May be I am too confident, but I have a tendancy to think it will never plug again, how could it, there is no more debris and no more gold crap.
Old 12-19-2012, 09:12 AM
-Snake-
-Snake- is offline
-Snake- is gaining momentum as a positive member of FTE.
Countless people have had their oil cooler clog after a chemical flush and installation of a new cooler, even with a coolant filter. I'm one of those lucky people, and I personally know at least three others. Even after a flush, there's still debris, sediment, and deposits in the cooling system. This stuff may be partially clinging to the inside of the radiator, coolant passages, etc and comes loose over time. Sometimes it takes years. Other times it only takes months.
Old 12-19-2012, 09:31 AM
kidoo
kidoo is offline
This was the case with my big coolant rad., it was full of Gold flakes and I could not get rid of it, I finaly replaced the rad. with a Bullet Proof one.
Old 12-19-2012, 01:30 PM
MauleOne
MauleOne is offline
OIL Cooler
Can I use a SCII to check out the delta on trucks I am test driving or do I need a hand held infra red type temp sensor?
Old 12-19-2012, 01:34 PM
-Snake-
-Snake- is offline
SCII is the most accurate way.
Old 12-19-2012, 07:28 PM
kidoo
kidoo is offline
If I would be buying a used 6.0, I would not buy it without using some kind of gauge. The SCII will tell you a lot of thing. You just plug it in OBD2 harness and do the set up for the 6.0
Old 12-27-2012, 01:00 PM
MauleOne
MauleOne is offline
Gages
Got one (SGII) on order. Will use it to check out trucks I look at.
Will post results.
Old 12-27-2012, 02:58 PM
kidoo
kidoo is offline
There is a lot of knowledgeable people on this forum to help out with the readings, good luck.
Old 12-27-2012, 03:57 PM
VQT
VQT is offline
VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.
Originally Posted by cheezit View Post
ive replaced a few hundred of them. its a 4 hour job
Pleeeassee Excussssa us newbie, it took more than 4 days not 4 hrs
Old 12-27-2012, 05:37 PM
cheezit's Avatar
cheezit
cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
the first one SUUUUUCCCCKKKKKEEEDDDDD.
but keep doing them it gets way faster. and even faster when your paid by the job
Old 12-27-2012, 05:43 PM
VQT
VQT is offline
Got it cheezit
olfordsnstone
08-19-2016 05:34 PM
JohnInCanada
08-07-2014 07:49 PM
Dgpz1100
04-11-2012 10:49 AM
Thor77
10-06-2011 09:42 PM
Wrapn3
06-24-2010 07:59 PM
Quick Reply: 6.0 Oil Cooler Replacement
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
