Power Point Fuse Location
On your 1995 F250 the lighter would be fuse #16 (15AMP) and the power point would be fuse #9 (25Amp) in the IP fuse panel.
Power Distribution
The Generator and Battery are connected together at the Starter Relay hot terminal. Other circuits originate at the Starter Relay hot termianl and are protected by fuse links. Low power circuits are protected by fuses.
The Ignition Switch and Main Light Switch are powered at all times, as are the Fuses 1,4,8,12, and 16. The other fuses are powered through the Ignition Switch or the Main Light Switch.
Power Distribution
work.truck
Electrical Systems/Wiring
03-12-2015 11:26 PM
myblkexpy
02-06-2011 09:02 AM
