Sponsored by: Real Truck
K&N Filter Dusting
Old Dec 15, 2012 | 08:40 AM
KenRebF-250's Avatar
KenRebF-250
Dang, you guys have got me feelin' bad about puttin' a K&N on our little 5.4. Is there anything good that can be said about the K&N stuff?
Old Dec 15, 2012 | 10:10 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by SasquatchZilla
So, during my many tasks on the truck these past weeks I took the K&N out for a cleaning. I've owned the truck for a year now and haven't serviced it. I have taken it out to inspect for cleanliness.
While cleaning the filter I noticed it wasn't very well oiled and while doing other tasks I noticed dust on the inside of the intake tube on the engine side. I believe the filter was sealing against the MAF body.
Wish I had could've got a pic. Has anyone seen this with a K&N filter?
So the filter was not properly oiled when serviced last time so it's K&N fault
I've had one in my present truck form 10K miles (when I changed out the original) and it now has 126K and there has never been any dust or dirt in the intake tube and I have never had to clean my MAF. If you follow the instructions they work just fine. I have also used them in my work trucks for years when I was still working with the same results.
Denny
Old Dec 15, 2012 | 05:18 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Agreed. I've had one in my SD for almost 30k miles and never had any dusting or oiled MAF sensor. Along with that I've had one in my '94 Explorer for about 60k miles with the same results. Same story in my wife's '01 Taurus with around 20k miles on it so far.
I keep them serviced properly and they seem to work fine.
Old Dec 15, 2012 | 06:51 PM
cay5628's Avatar
cay5628
We have been successfully running one with a FIPK on our 2001 5.4L. You just have to keep it properly cleaned and oiled. It just didn't work well on our V10 in the Excursion.
-Mark
Old Dec 15, 2012 | 07:00 PM
SasquatchZilla's Avatar
SasquatchZilla
Originally Posted by P.Bronner
The dusting issue with oiled gauze filters is an old one. All filters pass some particles. If you have a 15 micron filter, particles smaller than 15 microns will pass. I first witnessed the dusting on an '02/7.3 that I used to have. After consulting with several of my techno-buddies we couldn't decide if this was happening because the K&N was actually passing more dirt than the stock filter, or if it was because the inside of the tube was oily and catching the particles allowing them to be seen. When I called K&N, the representative was as cagy with his answers as their media advertising is in print. They talk all about flow, but the issue of filtration quality seems to be an unwanted nuisance. In fact, when I mentioned the possibility of "witnessing" due to the oily tube, he grabbed that ball and ran with it. He'd apparently not heard that one before and liked it a lot. Based on this, I tossed my K&N in the trash and went back to stock. I still have to wonder what the best filter media is though. I've owned Honda dirt bikes and ATV's nearly all my life that use an oiled FOAM filter and never dusted an engine or come anywhere close, and these are machines that are routinely ridden in very dusty conditions. I wish I knew what the right answer was because it seems logical that the oiled filter would be more effective at stopping dirt because not only is it using a physical barrier, but also has the added benefit of the oil to grab and stick to the particles that otherwise would pass. More than anything it was the company's (K&N) inability to give me a firm and confident answer that scared me away. They absolutely would not talk micron numbers. Someday when I'm rich and idle I'll buy all the necessary equipment and give us all the definitive answers!! -- As mentioned above, if you stay with an oiled filter you WILL have to clean the various intake tract sensors on a somewhat regular schedule.
Yeah, There was a Rep on a dodge forum and his PR was very very bad and his answers and tech info wasn't convincing regarding filtering efficiency. He also dodged the questions you mentioned. For that reason, I won't use them as well.
Denny
There was a smidgen of oil on it. If a paper element get's dirty the downside is a rich engine, possible egr issues and a loss of performance. Apparently when one of these goes bad it dusts your engine.
I too have used Uni filters amongst other brands on bikes and never seen this issue inside the intake tubes even if they run a bit short on oil.
Plus, Manufacturers aren't dumb and most intakes aren't that restrictive anymore, not that there isn't some that are. There are space concerns sometimes. I'd like to see the before and after mileage and power difference vs stock and K and N when I switch to stock.
I bought a oem style and it's a bit large to fit in the Banks box. Thanks for the heads up on the OEM one from the Excursion Jh818, I PM'd him.
Old Dec 15, 2012 | 07:55 PM
jh818's Avatar
jh818
You're welcome. Hope it works out for you.
Old Dec 15, 2012 | 08:02 PM
mikeismadness's Avatar
mikeismadness
I'll see if j can dig up an Article on testing different filters on a D-Max
Old Dec 15, 2012 | 08:12 PM
mikeismadness
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Found it!
Old Dec 15, 2012 | 10:36 PM
SasquatchZilla
Thanks Mike,
That's an awesome article and exactly what I expected. From the back and forths I've read on the diesel forums the manufacturers didn't want to talk about filtration effieciency, but only flow. In a limited use hi po filters like this would be fine in a race or maybe a few extra lbs of torque for towing, but day to day wouldn't be so good. Guess that's why that AIS intake system is so nice, but it looks like it's only for diesels. I don't think it'd be hard to adapt it to my truck, but the nearly 400 dollar price tag is a bit steep. I live off an extremely dusty dirt road (in the summer) and have to check the filters regularly.
I'm not trying to stand on a pedestal and p*** in anyone's cheerios, just sharing an issue and asking if anyone's had similar issues with them. If you've had good success with them, then I'm glad. But I'm not. And I might switch out my Uni filters on my bikes too after that article.
Old Dec 15, 2012 | 11:24 PM
parkland's Avatar
parkland
I put K&N on my 7.3, it let a whole bunch of dust past.
I sent pictures and they sent a replacement, but I ended up going factory.
I put an AFE system on my 6.4, and the AFE rubber intake boot on the turbocharger cracked right in half allowing the engine to intake raw unfiltered air for at least 1 oil change before I noticed.
IMHO most aftermarket stuff is complete crap.
Thats 2 aftermarket air filter and 2 failures, that could have easily toasted my engine both times.
They can keep it and pound sand for the extra +15 HP or whatever.
Old Dec 15, 2012 | 11:26 PM
jon75070's Avatar
jon75070
my $.02 cents.... on my 08 6.4 I bought two k&n filters (stock replacements ) one to run and one to clean (cause I know I can be lazy) ....swapped them at every oil change well as luck would have it i never cleaned the dirty one and was in a hurry had my goose neck already on the truck headed out of town .....did oil change threw paper fram filter in and was like WTH!!! EXHAUST TEMPS WENT DOWN 200 DEGREES ! never put k&n filter back in it again ..... IMHO on the 6.4 the paper filter has a ton more surface area vs. the hollowed out k&n .....like 5-6 times the area
Old Dec 15, 2012 | 11:30 PM
parkland's Avatar
parkland
The 6.4 stock filters are nothing to laugh at.
I would try to keep it stock until I really couldn't any longer.
Old Dec 15, 2012 | 11:32 PM
  #28
SasquatchZilla
Nice boat Parkland.
Old Dec 15, 2012 | 11:41 PM
  #29
parkland's Avatar
parkland
Nice boat Parkland.
Not mine, just rented for a trip a while back.
I am looking for a similar sized one though, but it's tough cause all the bigger boats are too wide to pull.
It burned about a gallon an hour @ 9 knots, and slept 4 easy. Bathroom kitchen everything you need for a cruise
leadfootal
Aug 5, 2008 02:53 PM
93F250
Modular V10 (6.8l)
13
Sep 18, 2007 08:19 AM
skilife17
1997 - 2003 F150
Mar 22, 2006 12:50 PM
Greg250
Jul 15, 2005 06:44 AM
Edmo
Modular V10 (6.8l)
Mar 13, 2004 08:00 PM
