Easy manual choke conversion...
Old Dec 16, 2012 | 12:01 PM
rustywheel68's Avatar
rustywheel68
There was an 1100 on the truck when i bought it. The power valve was frozen solid, and i couldn't un-stick it. I had the 2100 sitting on a shelf from a former project. I've always liked it- it used to get 16mpg highway on a 360 FE.
I have the truck at a point that i can drive it around the neighborhood- I will say...with the 2100 and the EFI manifolds, its got a little kick in its step.
But, the 1100 never ran right while I owned it, so i don't have anything to compare it to.
Old Dec 16, 2012 | 12:37 PM
parr4's Avatar
parr4
I'm hoping to find a cam-link for my YF. Mine 'disappeared' some way. If you might have one that you don't need, I'd sure appreciate it. Thanks
Old Dec 17, 2012 | 07:59 AM
rustywheel68
i don't have any YF stuff, but i'm sure someone could help you out- may want to start a new thread asking if anyone knows how to get one?
Old Dec 17, 2012 | 09:09 AM
parr4's Avatar
parr4
Thanks. I did post in the Classifieds. Nothing yet tho....
Old Dec 17, 2012 | 09:38 AM
rustywheel68
is this it?
Carter 1 bbl YF Fast Idle Link Carter 117 206 | eBay
if not, parts carbs are pretty cheap- would just have to make sure its the right one.
Carter YF 1 Barrel Chevy GM Ford Mopar 1940's 1 5 8 Throttle Bore | eBay
Old Dec 17, 2012 | 09:55 AM
parr4's Avatar
parr4
Thanks, not according the posted picture. That piece looks like the pump-connector link.
I called the local Ford store and the parts guy gave me a Motocraft # CM2270 for the fast idle cam link, but everything is long-ago discontinued.
I appreciate the help, thanks
Old Dec 21, 2012 | 10:23 PM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
I did a similar setup for the 1bbl carb on my 300. I used a throttle for a lawn mower. Im thinkin about switching to a 2bbl rochester carb. Would that be too much for a stock 300?
Old Dec 22, 2012 | 07:12 AM
rustywheel68
2-bbl should be fine. lots of people even using small 4's.
your signature line may be the funniest thing i've ever seen.
Old Dec 22, 2012 | 09:31 PM
LITTLE BLACK TRUCK
Thanks, I got my signature from the HAMB.
PA F250
Jul 25, 2014 08:19 PM
abyars111
Sep 28, 2012 04:43 PM
datchew
Feb 26, 2007 11:08 AM
cbfomoco
Feb 6, 2006 09:58 PM
