1966 F-250 Lift kit?
To use a longer coil spring, you'll have to drop the pivot point on the I-beam and the radius arm bracket. If you don't the suspension geometry will be off, it'll eat tires, and handle like s%&!. Maybe you can cut the old brackets off, build some spacers, and weld it back together. Let us know, I would like to do it also.
on
Hi,
I've been trying to find a lift kit for my 1966 F-250 2wd for a while now. I want to raise the back 3 or so inches, and want the front equal height, no more rake. I too thought about blocks for the back, and longer coils for the front. The spring shops I talked to said they wouldn't make them any longer than 2" or 3" inches from stock. Can't find an off the shelf lift anywhere. Thought about cutting the brackets off a 4X4 and mounting them on mine. Anyone have thoughts on that? I followed the I beam link and e-mailed them. They said they don't make I beams for my truck. Is that because I't a F-250? Would they work, anybody know? Anybody have any more suggestions? I want to get my ducks in a row, getting ready to rebuild drivedrain, convert to ps, pdb, and rebuild brake system. Thanks.
T.J.
T.J.
hppydrunk,
did you ever succeed in lifting your 66 F250 2WD? i have exact same thing and i also want to get rid of the rake angle that my truck has. i want a nice level stance a bit higher up. what did you end up doing?
can you send pics or other info on what you bought or used to get this done?
many thanks!!
many thanks!!
LDCF250
147
10-09-2017 09:19 AM
1966f250
03-17-2016 04:09 PM
1966, 51, 66, f100, f250, ford, justspindlescom, kit, kits, lift, lifted, merc, sleepwalker, truck, wwwjustibeams, wwwjustspindlescom
