need help
Old Dec 9, 2012 | 03:56 PM
Kvfd6530's Avatar
Kvfd6530
need help
i was drivin the other day and my truck just quit. i had one injector wiring harness that the clip was broken on so changed it now the truck will crank and run for about ten seconds and die. it acts like it is runnin out of fuel. does anyone have any ideas???
Old Dec 9, 2012 | 04:42 PM
JT250's Avatar
JT250
in tank screens getting clogged? fuel filter? are you sure you have good fuel pressure? do you have any way of checking it?
Old Dec 9, 2012 | 04:51 PM
Kvfd6530's Avatar
Kvfd6530
the tank is clean pulled it like 2 weeks ago, replaced the pump and filter at the same time as dropping the tank. not sure on exact psi but strong enough i could not hold my finger over the supply line comin into the fuel bowl.
Old Dec 9, 2012 | 05:07 PM
JT250's Avatar
JT250
Look at the last link in Tuglys signature. If you go through all that stuff you will likely find your problem.
Check foe chafing on the wire harness coming out pf the 42the pin plug. That is a common problem.
Old Dec 9, 2012 | 08:55 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Quick fuel check....... Open the water fuel separator valve with the key cycled on "NOT STARTING" a few times to make shure your pump is still pumping. Just a good way to rule out the pump.
barngoddess
15
Oct 23, 2011 03:37 PM
altruego
May 17, 2011 04:04 PM
tralfamadorian
May 30, 2009 09:35 PM
edub32
37
Jan 28, 2009 07:21 PM
EXPL4X4
Mar 22, 2006 10:33 AM
