How Can I Install A Sub And Amp On My Stock Head Unit
System in wife's truck
I'm putting a system into my wife's 14' FX4, using factory HU/Navi. My question is with it having the factory Sony system, am I able to use factory plug for amp not to power aftermarket but to send signal? If anyone has done this or now where I can find a plug adapter please let me know.
Hello
I took my sub and amp out of my SD when i traded it in and i want to put it in my new truck but it has a stock head unit... Im not wanting to put a new deck in so im curious if anyone knows how to do this with the stock stereo. I have a 2012 f150, thnx in advance for the help
13 f 150 sub install
Absolutely possible, you will need the following:
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
This will let you turn the 4 high level speaker inputs into RCA low level inputs for your 4 channel amplifier.
You will need to run speaker wire from the head unit to the amp and then from the amp to the speakers. I recommend using this stuff: EFX FS9W-25FT FLux 9 Conductor Speed Wire Speaker Cable
It will let you cleanly run the wires to and from the amp. Get the metra ford head unit connector and you can keep all ford wiring intact so you can uninstall the amp easily with keeping the headunit functionality intact if you want to sell the truck in the future.
Here's the answer
Lc2i is a 2channel line output converter, get a plug from Best buy that mates to your factory amp plug.. it's basically plug and play from their.. I'm waiting on an lc8i, to finish my install, I won't be happy with the factory highs after I have 2 12in and 1 10in Alpine type r under my back seat..
Installed myself 10 f150 factory head unit with nav etc
Bryan Kemp
08-15-2017 09:54 AM
twinpeaks
02-14-2010 11:43 AM
il67bp
1997-2006 Expedition & Navigator
12-28-2008 11:54 PM
ktplotts
08-29-2005 01:18 PM
