See the plate that says start on off? Push the ignition from behind toward the cabin and twist the plate on the outside counterclockwise 1/4 turn and the ignition will pull out from under the dash.
If my foggy memory serves me at all, I think there is a small hole in which you insert a small drill bit or similar to release the lock cylinder from the switch.
