Sponsored by: Real Truck
Drive train shutter/vibration
Old Dec 9, 2012 | 10:40 PM
LMS Residential's Avatar
LMS Residential
Originally Posted by SDTriton250
My frame or exhaust will occasionally ring in my XLT under load. Not sure what it is but I don't lose sleep about it. What caught me attention was seats. Did you install aftermarket seats in your truck? My 8 way power seats are on par with cheap folding lawn chairs. I would love to install some better seats in my truck.
Sorry to the OP for a quick hijack.
TRiton, check out this thread.....
https://www.ford-trucks.com/forums/8...uestion-2.html
Old Dec 9, 2012 | 11:14 PM
Yahiko's Avatar
Yahiko
I would wonder if maybe the transfer case was the cause after
what you just said. Just to play with things you could remove the
counter weight and see what it does. Also do to the year I take it's a 6.0.
Come on over to 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
and ask we have a few Ford techs that are very helpful.
I agree on the $500 offer
With the 6.0 at least you can work on it with out getting $50,000 in computer
gear like for the new ones.
Sean
Old Dec 10, 2012 | 07:35 AM
P.Bronner's Avatar
P.Bronner
It IS an alignment/ angularity issue, and the reason nothings changed is that nothing has changed. You simply replaced the driveshaft with another just like it. Try shimming the center down and see what happens. I had the opposite problem with my '11 in the form of a loaded launch shudder. I removed the support bracket and shortened it by about 9/16" and cured the problem. Shimming down is a lot easier than this, and worth the few minutes and bolts/washers required to do the job.
cheezer37
2009 - 2014 F150
Dec 21, 2018 08:01 AM
oscoda455
34
Jul 10, 2016 08:12 PM
97ExpGuy
Feb 9, 2009 07:35 PM
jdrose
Jul 13, 2005 07:05 AM
Stephan
Aug 23, 2002 01:23 PM
