Ford Dealer said to Flush and Upgrade to Gold 6.0 Ltr Coolant?
I was visiting my local Ford dealer today in the part dept asking for those test strips to test the coolant. He told me I should flush it out and upgrade to what they put in 6.0 which is the gold stuff at 17.00 a gallon. I thought, well how much is it, he pointed the board where is said coolant service 69.95, I said, I have a 7.3 diesel really 70.00 bucks, can I schedule today. He then checked and said, whoops they wrote it wrong on the board it should be 169.99. so I said that puts it in my DIY category. Is it common to change to the gold from the green. I know WoodnThings gave me some great advice on coolant (time to look that up again). I was going to argue and hold him to the advertised price since he couldn't tell what is different from a coolant service and coolant flush .
Got a chuckle out of this part of your sig "lotsa Riffraff stuff". No chit.
Here ya go bud.
Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
LOL, yeah. Without a lot of sig room, that was the easiest way.
Stewart
Stewart
Stewart,
I think I am going to gear my confidence up to do a flush and coolant bypass with the radiator hose change (the one that goes around serpentine belt). My issue is the mess and disposal (ugh). Thanks for the info and year check. I just finished the hutch/harpoon mod. Wanting to do a DP tuner - trying to convince the GF that it will save on mpg's , then sound proofing.
Oh ya, you know what just happened last week was the slow rear window thing, they barely rolled up. Yet another subject to search for .
I did the swap to ELC about a year ago, swapped out all the hoses, the WP, new stat & housing and a coolant filter. Aside from a minor leak at the billet housing fixed with a sealant, all has been fine. I was lucky, I had a shop with a lift available to work on it, I think I went through 36 gallons of distilled water in several fill and drain sessions. Wasn't a hard job at all, as already noted a little messy and a little time consuming, I used 13 bay hours for everything. I used 4 gallons concentrated Final Charge ELC from o'reillys at $25 each.
