How do Ido a hutch mod
Evilink*,
I just finished doing this, me and another FTE fella.
It's much easier than you think, the instructions from the link above are great. I would add a few notes below.
First my truck is an F350 2000 7.3
I was nervous to disconnect the fuel lines and electrical connector but you can almost completely drop the tank to the ground before having to do this - actually if you keep it about 14" off the ground those conenctors are easier to get to. I had a little trouble disconnecting the two tubes that connect to the gas cap area - but there are three gates clamps - its easier if you loosen up all three.
Be sure to buy the correct 10' tubing, diesel and fuel pressure rated. I asked for tubing, he sold me the wrong stuff, and just by chance, just before I raised my tank I called Napa and the guys said, sorry we sold you the wrong stuff. It would have collapsed had I used it.
An FTE member said to fill the tubes with sand before you bend them, good idea - I didn't, but it would have been easier to fill with something so I wasn't so nervous to bend them. I found stainless at local farm store (wilco), otherwise like they said, other tubing will work.
I just used WIX inline filters - they seem to do the job. Don't forget to do the harpoon mod - I went and purchased PVC cutters and it worked surprisingly well.
Take your time lowering the tank - TUGLY can do it in like 15 minutes, it took me almost 2 hrs. My first time, so I was very careful and nervous and used cribbing to make sure I didn't mess anything up.
Once the tank is down, siphon the rest of the fuel out, it will make putting it back up easier. Some guys talk about doing a tank rinse - I didn't because I didn't know how - I just used a terry cloth towel and wiped it down inside to get all the little debris.
Other than that, it was much easier than I expected, my confidence was the only thing hindering me. I have a great deal of respect for FTE members, I would ask a question, instantly an answer - it was almost as if they were in my shop with me. It really helps knowing you have FTE in your pocket when needed.
Good luck and don't let it overwhelm you, its not nearly as involved as it looks.
This was the thread we were using just today in fact.
https://www.ford-trucks.com/forums/1...ication-3.html
is there a good way to bend the pipe if and when I find it. when I get to that point of this mod.
or will I have to buy the bender for a one time job?
I am also curious about the tank wash, I have a van and its metal. adn after doing my fuel bowl. I will be doing something with my tank for sure.
15 minutes on the 3rd and 4th drops... much longer on the first drop. You can reach the vent tube in back just in front of the driver-rear tire. Shine a light in there and you'll see it. The other vent tube is forward of center of the tank. A mirror and light will show you where it is, there's enough room to reach it before dropping the tank. I dropped the tank without disconnecting the sender wire and fuel lines until the tank was down... plenty of length on those. The fill and fill vent hoses are trickier to manage while dropping.
TKegs763
18
09-16-2013 09:32 AM
rideracelivemx7
07-25-2009 03:35 PM
ebbnflow
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-17-2007 12:04 PM
