I have a 2008 F450 I bought. I live in the Denver CO area and we have to emmision our trucks and all the exhaust has to be there. Does anyone make a replacement canister that is gutted?
I think that there is a back pressure signal that is needed by
the PCM and if it not where it should read it will pop up a CEL on you.
That would not be good when going in to be tested.
There are videos of people cleaning there DPFs on Youtube, some EPA approved, some using a more permanent method. The permanent method I believe your more interested in they take a large masonary drill bit and hog out the center of the DPF.
Hi
They run it on a dyno and sniff the exhaust. I had planned on getting a programer too. As many people that are removing them I would think they would be available in somebodys garage. Has anybody had expierance with the water injection with these?
Thank you for the replys.
Your gonna have to get a DPF delete pipe and then switch it back and retune to stock programming in order to pass the inspection
or
Get a dpf friendly, carb approved tuner.
Hi
My F450 Is a White king ranch 4x4 crew cab dually with a long bed and 4.30 gears. It has 32" tall tires. I got 12.3mpg running at 70 mph on a 2000 mile round trip from Denver to northeast Mo. I want some more power and mpg. Dieselpower mag in the December issue had an article where they left all emissions on. They used a Bullydog intake,bullydog GT programer and AEM water injection. They liked the results. They got more power and less smoke with the programer and the water injection. I may have to go that way, if they have more information about it. I reprogramed My2000 F350 every time i had it emissioned so that would not be a problem. Thank you for all the information
