1995 Ford F250 351 4WD Under Hood Fuse Box Diagram
Old 08-28-2016, 08:21 PM
subford's Avatar
subford
subford is offline
Originally Posted by pjtn
No spark last week so replaced ignition coil ( very hot to touch) and truck ran for two days - would be happy to check PIP -looking for info
Sounds like the Ignition Control Module (ICM) was grounding the coil all the time (bad ICM). With the key on a loading (non LED) test light should light at both of the small wires at the Ignition Coil. If it does not either the coil is open or the ICM is bad and grounding the wire to the Ignition coil or the wire is shorted to ground.
arkiados
11-29-2022 08:31 AM
Curated Content Editor
2009 - 2014 F150
08-25-2018 04:22 PM
kuzco
11-08-2009 05:57 AM
mickeyderry
04-05-2008 09:33 AM
Biggfoot
12-23-2006 10:49 PM
Quick Reply: 1995 Ford F250 351 4WD Under Hood Fuse Box Diagram
