'96 Explorer transmission issue.
Old Dec 5, 2012 | 05:45 PM
miketwiss20's Avatar
miketwiss20
Was wondering if anyone can offer some advice. My wifes explorer has a long delay when shifted in to reverse when its cold. When it warms up it almost completely clears up. My gut reaction was filter and fluid chanfe but it made no difference. Also when cold it will hold forward gears for a long time not getting past third until it triggers limp mode. Once that happens she can stop and turn off the car and restart it and then its fine. If anyone can provide some direction i would be very grateful. Thanx, Mike.
Old Dec 5, 2012 | 09:29 PM
impish's Avatar
impish
First, are any trouble codes present? My guess would be a hydraulic pressure problem, possibly related to a solenoid. Have a pressure check run, both when cold and hot.
Just a thought. impish
Old Dec 5, 2012 | 09:42 PM
miketwiss20
Not that i have been able to pull yet. One of those things the time i was able to.get it on a computer we couldnt get the thing to act up! I appreciate tje thought I was unaware that trans pressure was something that could be checked. Ill have to get it im the tranny shop and see what they say. Thanx!
Old Dec 6, 2012 | 10:55 PM
impish's Avatar
impish
These transmissions, yours likely either a 4R44E or 4R55E, are told which gear to engage by the computer, including the initial engagement, whether "D", "R", "2", or whatever. After initial engagement, subsequent shifts are all brought about electronically.
Meanwhile, the computer, knowing how hard the engine is working, and how fast it is turning vs. vehicle speed, "tailors" the hydraulic pressure to make all shifting conditions optimal for the transmission. In other words, shifts are easy, sooner, and smooth, when the engine is not developing BOO-COO power, as a result of varying "control pressure".
It all sounds terribly complex, but is not in reality. Speed sensing of the transmission's internal shafts, allows the computer to know if something's amiss, if it "sees" inappropriate shaft speeds, and can thus deduce the like reason for that, and call it out as a digital trouble code. Self-diagnosis, if you will, taking away a whole lot of bull**** and guesswork as occurred in the past. impish
Old Dec 15, 2012 | 06:46 PM
miketwiss20
UPDATE! Tore everything down today, and found: Intermediate servo cover cracked (nit sure what caused this), top valve body gasket blown out, torque converter pump drive hub stripped! Everything else looks good. Checked biost valve and spring thinking mayve that caused an overpressure but it checks out so. Replacing all the bad stuff and reassembling tomorrow.
BruteFord
15
Jun 29, 2014 08:17 AM
towvan
1997 - 2003 F150
Jul 24, 2010 07:13 PM
exploder96
May 5, 2008 04:17 PM
dandy deke
May 6, 2007 10:51 AM
ISHERWOOD
Sep 3, 2003 11:23 PM
