Knob/Switch locations
Old Dec 5, 2012 | 09:58 AM
davewave649's Avatar
davewave649
****/Switch locations
I am trying to figure out what would go in my remaining hole in the dash. Like all these trucks my truck has 6 holes stamped under the opening for the gauge cluster for the various *****. so far i have 5 of them filled. What would go in the hole closest to the steering column on the passenger side? I already have wipers, lights, a cig lighter, choke cable, heater plus a switch for hazards and a bezel for the hazards however those two are mounted in holes stamped on the cluster. So whats left that I'm missing, or what could go in the hole?
Old Dec 5, 2012 | 10:33 AM
J_Dillon's Avatar
J_Dillon
I THINK but cant remember for sure because it has been a while since I pulled mine apart so I am probably wrong but for some reason I think I had one that was a "dummy" whenever I pulled mine apart. But like I said I'm probably wrong. Ill dig through some pictures to see what I can find
Old Dec 5, 2012 | 10:42 AM
davewave649
It very well could have been. Mine currently has a chrome plug filling the opening, which looks fine but I'd rather use that opening for something instead of mounting an extra switch somewhere else (ie my headliner/console that I'm working on)
Old Dec 5, 2012 | 02:14 PM
ShadowSnowLeopard's Avatar
ShadowSnowLeopard
Mine is a dummy. Looks jiust like the other ***** but is totally non-functional, well except for filling that hole! Perhaps a good spot for some custom add on?
Old Dec 5, 2012 | 03:29 PM
J_Dillon's Avatar
J_Dillon
Well guess I wasnt too far off after all Yes thats a great spot if you want to retain the factory look!
Old Dec 5, 2012 | 03:49 PM
davewave649
Hmmm you guys mind posting up some pics of what yours look like? Cuz they definitely aren't the same as mine
Old Dec 5, 2012 | 03:55 PM
ShadowSnowLeopard
I will try to remember to take a couple when I get home. Probably will be too dark though.
Old Dec 5, 2012 | 04:13 PM
davewave649
no rush, unfortunately i wont be able to work on the truck for the next 2 weeks or so anyway
Old Dec 5, 2012 | 04:41 PM
Boss9F100's Avatar
Boss9F100
Right side of column
Flasher Light
Flasher
Choke
Heater
Left of Column
Washer above ignition if equipped
Ignition
Lights
Wipers
Lighter
The furthest left hole right of column a lot of times would have a little stainless plug. Have a few laying around . . .In place of Flasher Light
<center>
<img src="http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20427/Interior/db511e82.jpg">
<br/><br/>
</center>
Old Dec 5, 2012 | 05:30 PM
davewave649
Thanks Boss, my flasher light and flasher switch are mounted on my gauge cluster as so:
Since taking that picture ive added a cig lighter in the hole on the left side.
So im wondering what else could fit in that hole...
Old Dec 5, 2012 | 05:36 PM
sgettin's Avatar
sgettin
i put a throttle **** in mine. no clue what was original equipment but it matches everything else (i.e wipers, cigar lighter, lights etc). you'll need it if you ever want to run your corn elevator off the pto on the truck. edt: btw i have the same style dash as you.
Old Dec 5, 2012 | 05:40 PM
davewave649
haha so do you think a choke **** would fit in that hole? I already know a headlight switch wont work (bracket in the way) but if i can move the choke **** to that hole i would be able to put my extra headlight switch in there
Old Dec 5, 2012 | 05:48 PM
1965GTFB's Avatar
1965GTFB
Hey Boss9,
What year is the dash pic of? Also what is the difference between the INst. cluster like yours and the type without the outer 2 gauges? My original '65 Cus. Cab. doesn'e have the outer 2 gauges but i picked up a whole cluster that does.
Thanks
Old Dec 5, 2012 | 05:55 PM
1972RedNeck's Avatar
1972RedNeck
Grandpa's '65 and my '66 have a throttle cable there.
Old Dec 5, 2012 | 06:00 PM
sgettin's Avatar
sgettin
give it a try just please don't drill the dash anywhere . i should take a pic of mine. i think it goes wiper, headlights, iforgotwhat, throttle, choke, heater. i did notice your ***** on the left don't look original but hard to tell from here. maybe originals fit better or something?
and why does the word **** keep getting #### ed?
my freakin internet is about to go down.
