E40D high RPM shifts
Ok, so this is my first Ford and first truck. Anyway about a week ago when i picked up my 1995 F-250 XL with the 5.8 Windsor i decided to drive it home. while i was driving it the engine was screaming in each gear and when i slow let off the throttle it was shift into next gear. 3rd and 4th overdrive were switching back and forth a lot. When i got home i noticed that the transmission pan was leaking which i will be replacing. Any thoughts on what could be the problem.
165,000 miles on the engine and transmission
check engine light was not on.
transmission did not seem to be slipping in any gear at all.
Fuel Injection Technical Library » How To Run a Self-Test Here is a link on how to check for trouble codes (even if no light on). Maybe do that first.
Richard2212
Escape & Escape Hybrid
07-17-2016 09:31 AM
Laneely84
10-27-2015 05:12 PM
contourdesigns
10-27-2008 10:43 AM
