Fender flare help
Old Dec 3, 2012 | 09:04 PM
joeyd61's Avatar
joeyd61
Fender flare help
last year I had my Bushwacker fender flares coated with line-x..I am in need of the rubber strips that go between the flare and body..The stock ones are to small.I have thought of using vacuum line and split it,but I no longer have the steady hand to cut it straight....Any ideals???
Old Dec 3, 2012 | 09:11 PM
JOHN2001's Avatar
JOHN2001
Could you have a friend cut it for you? Maybe a neighbor? I have a similar problem with one of my flares too but it's not so bad to have to worry much about it
Old Dec 3, 2012 | 09:12 PM
guitarpicr's Avatar
guitarpicr
Does Bushwacker make them for your flare ?
Old Dec 3, 2012 | 09:50 PM
joeyd61's Avatar
joeyd61
I have thought about that...
I sent them an e-mail last week and have not heard back...The stock ones are to then
Old Dec 3, 2012 | 09:55 PM
JOHN2001's Avatar
JOHN2001
To be honest I would get something you can have someone cut for you so you know you won't be replacing it again a year from now. IMHO they are too cheap for what we have paid for the flares.... They look great though
If you were closer I'd cut it for you... I've got that steady welders hand
Old Dec 3, 2012 | 10:07 PM
tappit01's Avatar
tappit01
dont no what size tube you would be workin with but, how about set up a jig of some sort. screw down 2 pulleys next to each other on a piece of plywood maybe, with a hole in it to fasten a carpet knife right behind the pulleys from underneith. then just pull the hose through
Old Dec 3, 2012 | 10:15 PM
petrokiller's Avatar
petrokiller
Joey maybe I can help you cut them. Wood dow rod in the hose and a square maybe to keep the line. Oh yeah, and a few clamps.
Old Dec 4, 2012 | 02:47 AM
BigAlsPSD's Avatar
BigAlsPSD
This sounds like a good opportunity to try this tip from Stacey David.
<iframe width="560" height="315" src="http://www.youtube.com/embed/2Q2OzraoxRE" frameborder="0" allowfullscreen></iframe>
Old Dec 4, 2012 | 04:59 AM
dn29626's Avatar
dn29626
I like that cutting tip!
Old Dec 4, 2012 | 05:08 AM
Firefighter 1406's Avatar
Firefighter 1406
That is a pretty good tip, always like watching that guy.
Old Dec 4, 2012 | 06:28 AM
429 f-100's Avatar
429 f-100
awsome tip from stacy i like that trick i was thinking door edge gaurd it is made to go on the edge and its made to be out in the sun and some have an sticky stuff in the groove to keep it in place.
Old Dec 4, 2012 | 12:05 PM
officer131's Avatar
officer131
<IFRAME src="http://www.youtube.com/embed/2Q2OzraoxRE" frameBorder=0 width=560 height=315 allowfullscreen></IFRAME>
Luckily someone remembered the clip here. I was going to attempt to type it out. Great idea.
Old Dec 4, 2012 | 02:11 PM
joeyd61's Avatar
joeyd61
Thanks for the input, a lot of great ideals....Bushwacker got back to me today and they are sending me what I need..
Old Dec 4, 2012 | 08:21 PM
crop harvester's Avatar
crop harvester
glad you got it figured out,otherwise I was going to suggest trying to warm up your stock rubber ones with heat gun.
luny1
Ford Truck Parts for Sale
Jan 27, 2013 11:14 AM
MetalSludge
2004 - 2008 F150
Feb 9, 2004 08:41 PM
armcan
Bronco II
Dec 9, 2003 01:48 PM
