Help to indentify this diff please
Old Dec 3, 2012 | 04:50 PM
freaky01's Avatar
freaky01
Hello people
I am currently in the middle of doing up a 1970 F100 and i currently am having trouble trying to find out what sort of diff i have and i was hoping that maybe by posting some pictures on here i may be able to get this sorted so if any of you could help that would be great.
Thank You.
Mick
Old Dec 3, 2012 | 04:56 PM
jowilker's Avatar
jowilker
Mick, Most 70 F100s would have a 9 in. Look on one of the bolts to see if there is a tag, then post the numbers on it if found.
John
Old Dec 3, 2012 | 05:02 PM
freaky01's Avatar
freaky01
hey John yeah im sorry i forgot to add it is a F350 diff dual rear wheel that where i have run into trouble.
Old Dec 3, 2012 | 05:21 PM
HIO Silver's Avatar
HIO Silver
Hmm... i like a good mystery. I've been searching all over the web and have been unable to ID that thing. How about posting the data plate info? You can of course decode the data plate here: Decoding Your 1970 Ford Truck VIN - FORDification.com
Second, what exactly are the numbers on the carrier?.. all I can make out is B276_ R... the underscore is the alphanumeric I cannot discern.
Old Dec 3, 2012 | 05:24 PM
lilsmokey's Avatar
lilsmokey
Welcome to FTE. Does that happen to have a NAPCO 4X4 Package on it? It looks very similar to my uncles ex-firetruck.
Old Dec 3, 2012 | 05:32 PM
freaky01's Avatar
freaky01
I dont have data plate details at all sorry the only details to find out what it is is those numbers in the picture. i have tried searching for the diff myself but some people have said it could be a eaton or a dodge but i haven't found any diff's with the back plate welded on so the only access is from the front.
Thx Mick
Old Dec 3, 2012 | 05:37 PM
freaky01's Avatar
freaky01
No it doesn't have the NAPCO 4X4 Package on it we have pulled it down fully and rebuilt it from scratch.
thx Mick
Old Dec 3, 2012 | 07:38 PM
HIO Silver's Avatar
HIO Silver
Thx Mick
Well at least ya tried to ID it on your own. Kudos...... that's more than others will do. I too thought it was a Dodge/Chrysler but not many dual rear wheel axles pictured on the web.
The "front access" is referred to as a drop-out (gear) carrier.... others, with rear access covers, are referred to as integral carriers because the gears have to be set-up within the axle.
It sure as heck looks like a Chrysler 8-3/4 by its banjo housing..... or it's some funky (and old) housing like from a commercial vehicle like a bread truck or small school bus. Dunno...
Old Dec 4, 2012 | 04:09 AM
jowilker's Avatar
jowilker
Hello people
Thank You.
Mick
Mick, You sure fooled me, with your "I am currently in the middle of doing up a 1970 F100" in your original post, then posting photos of what appears to be for a much larger truck.
John
Old Dec 4, 2012 | 04:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
How many F100's came with dual rear wheels? None / The rear axle has been swapped (OP sez from an F350) and it looks just like a...
The housing has a date on it, what I can make of it: 2 -1? -6? / Are the wheels 6 lug on a 7.25" bolt circle? / How many bolts retain the carrier to the housing, 12?
HIO Silver...away! The Lone Ranger traded Silver for a bread truck (P350), Tonto's riding shotgun. P350's used the same rear axles as F350's, but it depends on certain years which rear axle it is.
Actually Clayton Moore bought a 1969 Econoline "Cut-Away" from Ralph Williams Ford in Encino, then Ralph had a Class C Motorhome body mounted.
Old Dec 4, 2012 | 06:39 AM
freaky01's Avatar
freaky01
The date on the housing if that is what it is it is 2-17-54 as best guess a little unclear it is a 6 stud on a just over 8-8.5 inch bolt circle and the carrier to housing is a 10 bolt and the diff centre casing is just over 13" across. PS John it really is a 1970 F100 just with the dually it looks bigger than it is. Because we are in Australia, Dodge is not a big company here so any info from some friendly American counterparts would be greatly appreciated. Cheers Guys
Mick
Old Dec 4, 2012 | 11:39 AM
NumberDummy
6 lug wheels on a 8.75" bolt circle: 1953/56 F700/900 with a Timken H150 rear axle.
6 lug wheels on a 7.25" bolt circle: 1953/66 F/P350. 1953/60, some 1961/62 used Timken rear axles. Some 1961/62's, 1963/66's used Dana 70's.
Old Dec 6, 2012 | 04:39 PM
freaky01's Avatar
freaky01
Sorry for the late reply ive just been busy but thank you all for the advice i will take all the information you lot have provided and work it out from there so thank you all
Cheers Mick
bmoore79
Oct 1, 2018 04:10 PM
Brian's 48
Oct 19, 2010 07:24 PM
GETDOWN!!!
S. California Chapter
13
Aug 24, 2008 07:53 PM
