EEC Computers
Old Aug 22, 2002 | 02:48 PM
gamehunter's Avatar
gamehunter
EEC Computers
Old Aug 27, 2002 | 12:18 PM
Gates's Avatar
Gates
EEC Computers
Does anyone know if there are any differences between a 5.0 SD EEC (1988 vintage) and a 1991 F150 EEC, speed density?
Thanks
Old Aug 27, 2002 | 03:02 PM
chuckman's Avatar
chuckman
EEC Computers
nope, none at all. All the EEC's for a specific motor are the same from 1987-1995, some changed to mass air in 95, the rest in 96.
Old Aug 27, 2002 | 04:17 PM
Pastmaster's Avatar
Pastmaster
EEC Computers
There are different codes for different setups. A manual transmission 302 truck is different than a automatic transmission 302 truck. If you have the same truck setup as the computer came from, you should be okay. I battled this when I sold my computer chip from my 1993 F-150. It has a E40D, and I would have used it in my 89 with a AOD, however computers were different.
'93 F-150 loaded and modified!
Check my Gallery
Old Aug 27, 2002 | 06:17 PM
Guy's Avatar
Guy
EEC Computers
I have the EEC from a 1987 2wd F150 W/AOD in my truck and it runs fine. The AOD tranny is mechanically controlled by a cable.
Guy
Old Aug 27, 2002 | 07:36 PM
Gates's Avatar
Gates
EEC Computers
Sorry about this but by 5.0 I meant a mustang 5.0 with 5 speed and speed density will it fit my 91 f150 with 5.0 5 speed and speed density.
Sorry but thanks for the help
Old Aug 27, 2002 | 07:54 PM
Pastmaster's Avatar
Pastmaster
EEC Computers
Well, the firing order is the same, as is the speed density efi system. I would think it would work, if the pins line up correctly.
Check my Gallery
Old Aug 27, 2002 | 10:23 PM
gamehunter's Avatar
gamehunter
EEC Computers
I kinda had to laught when you chose to use the word vintage. Its what they are! Anyway, I thought all stangs had the 351 firing order? If it doesn't, it should work fine but actually might perform a little better if you have a few mods on it since the stangs came with a few more ponies than the trucks did. Just a guess.
