Check Engine Light on '92 2.3L Ranger - Code 327, 328, and 334
Hi,
I've got a 1992 Ford Ranger 2.3L with about 240,000 miles on it. The check engine light started blinking on and off pretty regularly so I pulled the OBD1 continuous memory codes and came up with this.
327 - EVP/EPT circuit below minimum voltage
328 - EGR closed valve voltage lower than expected
334 - EGR closed valve voltage high
I can't say these codes mean a whole lot to me besides I've got issues with my EGR valve and possibly the EGR valve position sensor.
I figured I would post and see if anyone had insight into these codes or the combination of them together. Any tips for fixing it? I was thinking I'd start by replacing the EGR valve. They're not too pricey.
Thanks a bunch.
Pad
Thanks a bunch.
Pad
Xdrive
1983 - 2012 Ranger & B-Series
07-19-2004 03:26 PM
