5.0L Trouble
Old Nov 29, 2012 | 11:59 AM
v8nate's Avatar
v8nate
5.0L Trouble
Hey guys.
So I recently traded my Little honda civic for my beauty and beast 94 F150XLT 5.0 with the Aode auto tranny in it. I love the truck but there are a few issues with it that I can't seem to figure out. I have been a mechanic for the past 6 years so stuff like this doesn't generally take this long.
heres the trouble i'm having. It runs fine but if I take a turn or going up a hill it feels like the tranny wont downshift and I lose almost all fuel pressure. Say the truck is in 3rd, when I hit a hill it won't downshift to 2nd to get me up the hill and the truck goes into a lub,lub,lub,lub mode with no power to it. if feels like i'm towing a diesel filled with bricks.
Any suggestions as to what it may be?
I have already replaced the plugs and wires.
I've been told so far it's either a vacuum leak, my alternator, fuel pressure, or my tranny going out.
I can't find a vacuum leak, according to the last owner a new transmission was just put in it 50k ago.
I do know my rear main seal is leaking
Old Nov 29, 2012 | 01:09 PM
Lead Head's Avatar
Lead Head
Check for any codes first.
I'd suspect a bad TPS.
Old Nov 29, 2012 | 02:32 PM
Glens67's Avatar
Glens67
Check the transmission wiring right where it contacts the frame, might be damaged there. Clean all of the wire connections for the trans too.
Old Nov 29, 2012 | 03:59 PM
v8nate's Avatar
v8nate
it is throwing a code for tranny speed sensor but I already replaced it.
Old Nov 29, 2012 | 04:07 PM
65cobra's Avatar
65cobra
You can test the TPS with a multimeter. Grab a shop manual or chiltons manual for the right voltages. Should be .9 vdc at idle if I remember right. Intake air charge temp sensor will cause loss of power too. Can't help with the tranny!
Encho's Avatar
Encho
The Southernmost Mod
To me that sounds like a vacuum leak, you should check that again. Even a stretched throttle cable could cause that.
Old Nov 29, 2012 | 06:18 PM
rla2005's Avatar
rla2005
What is that code by number please?
Old Nov 29, 2012 | 06:20 PM
v8nate's Avatar
v8nate
I will check that again. I actually plan on replacing/ rebuilding the entire truck once I get my other car working and can live without my baby for a while.
@Encho you seem to have the exact same truck as me, How do I check to see if my tranny is the Aode or Eo4d?
Old Nov 29, 2012 | 06:21 PM
rla2005's Avatar
rla2005
Your memory is failing you. Anything between 0.6-1.0 VDC is acceptable for the closed throttle TPS voltage.
Old Nov 29, 2012 | 06:27 PM
v8nate's Avatar
v8nate
P0705 Transmission Range Sensor out of Self-Test Range or Shorted to Ground
I had never seen it before and the master tech I work under as well as the parts house guy both said to replace the tranny speed sensor
Old Nov 29, 2012 | 06:39 PM
Glens67's Avatar
Glens67
Again
CHECK THE WIRING HARNESS!!!
rla2005's Avatar
rla2005
You have a 1994 F150 giving OBD-II codes. I don't think so. Your truck should have 3 digit OBD-I codes.
And the reference to Transmission Range Sensor is most likely the Manual Lever Position Sensor (MLPS) on the driver side of the transmission.
Old Nov 29, 2012 | 06:41 PM
rla2005's Avatar
rla2005
Check the door jamb sticker.
Trans. Code E is an E4OD (No transmission speed sensor)
Trans. Code U is a 4R70W/AODE
Old Nov 29, 2012 | 06:50 PM
v8nate's Avatar
v8nate
[QUOTE=rla2005;12539241]You have a 1994 F150 giving OBD-II codes. I don't think so. Your truck should have 3 digit OBD-I codes.
OBD1 code 653.
Old Nov 29, 2012 | 06:57 PM
v8nate's Avatar
v8nate
In the picture above I replaced the sensor on the top. not the one the cable is connected to
