Blinkers stopped working?
I have a 96 f150 with a 5.8L V8.
My blinkers have stopped working and I have no idea why. I checked the fuses and they're fine. The 4 way flashers still work. Another thing I noticed is that it also seems that a bulb or light behind behind the instrument cluster is not working because right where my fuel level and battery level are, it's darker than it was.
Any ideas???
Any ideas???
does your truck have an aftermarket plug in for trailer lights?.. I have a 75 f-250 now, and it had connection problem when I got it ...it had no signal lights... cured it but it took some crawling under the rear to check it all out.
I also had a bad brake light switch once on and older ford that caused turn signals to not work
87Ford250
10-06-2011 08:03 PM
scottlane
21
10-04-2005 08:27 AM
jakegypsum
04-24-2001 11:34 AM
