Which Holley Carb do I have
Old May 22, 2003 | 10:04 PM
Alex03's Avatar
Alex03
When I bought the truck it had a holley carb on it. The orginal owner said it was a 650 but i wanted to be for sure what series it is before I rebuild it. Does anyone know where the # is?
Old May 22, 2003 | 11:13 PM
Ford_Six's Avatar
Ford_Six
If you look on the front of the choke housing, there is a series of numbers stamped there. If you post that, i can tell you all the stock info about that carb.
Old May 22, 2003 | 11:58 PM
LxMan1's Avatar
LxMan1
Use the number that starts with LIST ?-????-?
This is usually the easiest way to find out. My money is on it's a 600!!
Jimmy
Old May 27, 2003 | 08:58 PM
Alex03's Avatar
Alex03
List-1850-1
0947
Old May 28, 2003 | 12:22 AM
Ford_Six's Avatar
Ford_Six
Model 4160, 600cfm.
Old May 28, 2003 | 07:20 AM
LxMan1's Avatar
LxMan1
This is a first generation 600 cfm universal Holley carb. I have used quite a few of these and they work fine. It may require a jetting change to run the best on your engine, but is should be pretty close. Just make sure that you don't have a screw in the slotted part on the secondary linkage. Alot of people do this to force the back barrels open too soon and will result in a nasty hesitation when you open it up due to the rear not having an accelerator pump. If you feel that the rear barrels aren't opening soon enough, you can get a spring kit to install a lighter spring. All in all, it's a good carb.
Jimmy
