1967 F100 4BT cummins daily driver build
  #226
Old 05-18-2015, 07:22 AM
bajafishnut's Avatar
bajafishnut
bajafishnut is offline
bajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to behold
This ride will roll forever, probably well past the life expectancy of the youngest Ford owner. Superb work amigo. The benchmark of excellence. Kudos.
Baja
  #227
Old 05-20-2015, 05:12 AM
f100today's Avatar
f100today
f100today is offline
f100today has a good reputation on FTE.f100today has a good reputation on FTE.
Got the oil pan shortened. I lost about 1 qt of oil.
  #228
Old 05-24-2015, 11:05 AM
f100today's Avatar
f100today
Making a little progress. Got the engine and tranny in.
  #229
Old 05-24-2015, 12:59 PM
Randle's Avatar
Randle
Randle is offline
Randle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant future
It is sure looking good, Your doing a great job on it. Let me change subject on you, would you need a set of inside door handles. When I ordered mine for the 70 NPD sent me a set for a 67 and when I called them they set me the right ones but said keep the 67's, so I have a new set still in the box, if you can use them I would be glad to send them to you.
  #230
Old 05-24-2015, 01:08 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
ultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud of
Cool build and very nice work.
I'm not certain if you have the stock small diameter Mustang II front rotors (?). [9.250" diameter]. From what I can tell from the photos, the rotors look rather small inside the wheels.
Even if they're upgraded to 10.5" or 11", that would still be small for all the weight added to the truck. Most MII kits were designed for much lighter street rods and cars.
All the additional weight added is going to add to the dynamics of the kinetic forces on the brakes, in trying to slow a vehicle in motion. Simply put, it's going to heavily tax the brakes that were designed for a much lighter car.
If the spindles are the stock designed MII, you can add 3-3/4" rotor diameter to those spindles by switching to 13" diameter '94-'04 SN95 Cobra Mustang front rotors, with 5-on-4.5" lug pattern.
This will also get rid of the heavier single piston MII cast iron calipers for much better and lighter Cobra PBR aluminum twin piston calipers.
This setup will require at least a 17" diameter wheel to clear the front Cobra rotors/calipers but, the benefits of much larger and much better performing brakes is worth it.
There were three SN95 Mustangs that had these brakes: '94-'04 Cobras, '01 Bullitt Mustangs and '03/'04 Mach 1s. The Cobras had charcoal colored calipers with the word "COBRA" written on the side (2004 10th anniversary Cobra calipers were red w/"COBRA" written on them). The '01 Bullitt Mustangs had a running horse logo on the calipers. The Mach 1 calipers (like on my '03 Mach 1) had plain charcoal calipers --no logos or writing on them.
In following photos: 13" Cobra rotors with '01 Bullitt Mustang calipers on the '75-'80 Granada spindles on my '68 Mustang --Granada spindle pins are the same as MII. Only difference is the ball joint mounts, caliper anchor brackets and the rotor diameter, --stock Granada rotor is 11.03" dia.
This will give you some idea as to the size of the Cobra front brakes.
Cobra-to-MII spindle adapter brackets can be purchased at the following link.
cobrabrakes
....the Cobra caliper adapter bracket on my '68 Mustang didn't come from MS. That 6061 T6 aluminum bracket was my design.
  #231
Old 05-24-2015, 01:21 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
How long do you think the 700R4 will last?
  #232
Old 05-24-2015, 01:56 PM
bajafishnut
I am loving this build, even though I am a F 250 4x4 man, all the way. This build has me singing a new tune. I cannot wait to hear it running...
Baja
  #233
Old 05-24-2015, 03:04 PM
f100today's Avatar
f100today
First off; thanks for the comp. Wow! Thanks for the offer! I already have some new ones from DC but maybe there is another member that could use them?
Thanks man. Thats a lot of good info right there. Unfortunately I am to the point of no return now. The disc are from a 2003 -2008 ram 1500; they are almost 12 inches in diameter and really thick. That truck weighs 1500 lbs more than mine and came with 20 inch wheels. The calipers are GM big bore, the spindles are forged steel, and I upgraded the ball joints to a K719 which is a much larger diameter shaft then the standard Chrysler / ford ball joint. I guess the disk look so small because of the 20 inch wheel? Looking back at this build, I should have done one of the aftermarket GM suspensions from Scotts or one of those. They are very heavy duty.
Not really sure. Pheonix is confident it will be fine. Hind sight; I wish I would have done the dodge auto tranny. If the 700r4 doesn't work out I will upgrade to a 4l80e.
Baja
Thanks Baja! You aint the only one that wants this thing running!
  #234
Old 05-24-2015, 06:11 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
Nice updates, F100, I hope you are enjoying your Memorial weekend!
  #235
Old 05-25-2015, 09:31 PM
71Nky's Avatar
71Nky
71Nky is offline
71Nky is gaining momentum as a positive member of FTE.71Nky is gaining momentum as a positive member of FTE.
I have one with over 440,XXL miles and going. And I drive them hard.
  #236
Old 05-25-2015, 10:12 PM
1972RedNeck
Not behind a hopped up 4 cylinder Cummins you don't. Big Block Chevy's eat "built" 700R4's for lunch. From experience, I would bet that the 4 cylinder will be even harder on it because of the less power "pulses" per revolution than that of an 8 cylinder or even 6 cylinder.
  #237
Old 06-07-2015, 07:52 AM
f100today's Avatar
f100today
Got the cab back from the painters yesterday. Overall I'm pretty happy with what they have done. A few little spots but the painter said he will fix after everything is done and I get the truck together. Good ole Wimbledon white. Original to the truck. I am letting it sit another week then I am going to put bedliner on the back of the cab where the bed goes and also a final coat on the firewall. Hope to have the cab on the chassis by next sunday.
They are finishing up the fenders, upper and lower front valences, and the hood. Doors and bed are next.
  #238
Old 06-07-2015, 08:43 AM
bajafishnut
Looking real nice amigo, better than factory.
Baja
  #239
Old 06-07-2015, 10:00 AM
Randle's Avatar
Randle
Randle is offline
X2 on that looks really nice.
  #240
Old 06-07-2015, 05:59 PM
71Nky's Avatar
71Nky
71Nky is offline
X3 on the looks
Quick Reply: 1967 F100 4BT cummins daily driver build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
