1967 F100 4BT cummins daily driver build
  #151
Old 11-15-2014, 09:03 AM
f100today's Avatar
f100today
f100today is offline
f100today has a good reputation on FTE.f100today has a good reputation on FTE.
Originally Posted by Randle View Post
I been snooping around in your thread. Good looking build, and good craftsmanship.
Thanks. I'm no body man so all the sheet metal work has definitely been the biggest challenge.
  #152
Old 11-15-2014, 04:25 PM
Randle's Avatar
Randle
Randle is offline
Randle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant future
I've always heard a person afraid of a challenge will never reach his full potential.
  #153
Old 11-17-2014, 12:23 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Thumbs up
2X. It is better to have tried and barely failed than to never have tried at all. Note my signature.
  #154
Old 11-17-2014, 05:37 PM
Randle's Avatar
Randle
Randle is offline
Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic.
Hay I like it, a whole lot of truth it that.
Trucks aren't Cool unless the tailgate handle swings..........
I like that to! Mine just swings a little different. LOL
  #155
Old 11-22-2014, 11:56 AM
Isuzu64
Isuzu64 is offline
Isuzu64 is starting off with a positive reputation.
Nice build. I to have a project not near The detail as yours. Great job. I have a 64 f250 Long bed. I have a Isuzu 4bd2 in it.
  #156
Old 12-15-2014, 07:31 PM
f100today's Avatar
f100today
12-15-14 update
Been working on the bed hot and heavy for the past couple of weeks. After getting the bed corner repaired I put the slight curve back in the passenger "bump" so it matches the drivers side. Got alot of the new bed fab going. I raised the bed floor approximately 5 inches from stock. The bed is now about 14 inches deep or so. Regardless, I fabbed a frame for the new floor along with wheel wells and two compartments for the battery and the air compressor. I still need to fab the closeout doors for those as well as the horizontal and vertical parts of the bed aft of the wheel wells. Also have some finish-out work to do between the bed floor to bumper interface. Hopefully all the bed fab will be wrapped up in a few more weekends then its on to the chassis.
Size:  1.85 MBName:  bedfab025_zps7cbb971e.jpg
  #157
Old 12-15-2014, 07:38 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
Nice compartments! Good idea.
Those trailer fenders?
  #158
Old 12-15-2014, 07:50 PM
f100today's Avatar
f100today
Yep. Fenders are from Northern Tool.
  #159
Old 12-16-2014, 12:57 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
You gonna put a Mustang tank back there? Now would be the time to fab the inlet pipe and door.
  #160
Old 12-16-2014, 05:55 PM
f100today's Avatar
f100today
No sir, I'm doing a 20 gal aluminum fuel cell; with a twist.
  #161
Old 12-16-2014, 05:59 PM
youngone1234's Avatar
youngone1234
youngone1234 is offline
youngone1234 is starting off with a positive reputation.
What is the twist. I am looking at putting a rear fuel tank in mine. I'm welding in the front fuel tank door off of a 79 f150.
  #162
Old 12-16-2014, 06:22 PM
w00ht
w00ht is offline
w00ht is starting off with a positive reputation.
Originally Posted by f100today View Post
I really, really like your dash. Really nice work all the way around. I look forward to seeing it come together. What kind of sound deadening are you going to put in the cab with the 4BT in there?
  #163
Old 12-16-2014, 06:41 PM
f100today's Avatar
f100today
Flush fuel door but using the fuel door hinge from a mid 90's f150. It will be better with pics.
  #164
Old 12-16-2014, 06:48 PM
f100today's Avatar
f100today
Thanks. I've decided to change the dash actually. I'm selling those gauges and going with a different brand. I'm also going to change the layout with a insert of sorts. Think F600 gauge cluster face. For sound deadening I sprayed second skin audio sound deadener on the inside of the cab all the way up and under the dash as well as on the firewall and bottom of the cab. Then I am going to use a layer of the thick fat mat, then a layer of closed cell foam, then the carpet with the jute.
  #165
Old 12-16-2014, 11:06 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Nice work on the bed...I was thinking of a trap door in the cab floor on mine for the battery but I think I like your idea better. Good place for extra storage too.
Quick Reply: 1967 F100 4BT cummins daily driver build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
