Help removing rear springs
The small nut holds a tapered pin in, this small pin is what holds the large shackle pin in. remove the nut and drive that small tapered pin out. Now you can drive the large pin out, some people have removed the grease fitting and threaded a slide hammer in, to remove the pin. Or there is a hole through the frame that you can access to drive the pin out with a drift.
Good luck in your quest.
From my experience and according to my parts book the sizes can very. I suggest that you remove them and take close measurements of pin diameter, spring eye inside diameter and pin length. All six shackle pins should be the same size but if your springs have been repaired you may have different diameter eyes.
hooler1
12-12-2015 10:20 AM
undertow91
07-06-2008 08:12 PM
TDS535
22
12-02-2006 09:10 AM
jeseitz
02-28-2005 04:11 PM
