Sponsored by: Real Truck
4.10 to 4.30 speed difference
Old Nov 21, 2012 | 08:37 AM
andrewzx92000's Avatar
andrewzx92000
Just went from 4.10 to 4.30 on my V10 two wheel drive with 245/75/16E tires, all stock. What will be the speedometer reading difference. I remember when I went from 3.73 to 4.10 it was about 10 percent at all speeds. The 4.10 to 4.30 change is about half of that in ratio.
Should I assume from that that the percentage of speedo error will be about 5 percent at any given speed.
Please help me with this equasion and thanks for the input
Andrew.
Old Nov 21, 2012 | 08:54 AM
jeep.hauler's Avatar
jeep.hauler
I have used this in the past to get close and then verified the speed with a gps.
4Lo.com :: Speedometer Check Calculator
Old Nov 21, 2012 | 08:59 AM
a4t1rat's Avatar
a4t1rat
Well if you figure you tire size is 31" and your over drive ratio is .71 then at 2250 rpm with 4.10 gears you would be going 71.31 mph. With 4.30 gears you would be at 68.0 mph so that is pretty close to your 5% or 3.4 mph
Old Nov 21, 2012 | 11:08 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Here is the equation:
Current speed * 4.30 / 4.10
So at 70 MPH your speedo will now read 73.4 MPH.
Old Nov 21, 2012 | 11:20 AM
andrewzx92000
Thanks guys, that has helped me, appreciate the responses
Andrew.
Old Nov 21, 2012 | 11:47 AM
SuperDutyScaler's Avatar
SuperDutyScaler
on a ford super duty absolutely nothing. Ford uses the tone ring on the ring gear to determine speed, even if you change gear ratios the tone ring still sees the same speed. Only thing that changes speed is if you change tire size
Old Nov 21, 2012 | 11:49 AM
Bigpipes 35's Avatar
Bigpipes 35
That is correct
Old Nov 21, 2012 | 11:55 AM
SuperDutyScaler
see i knew all that reading up would help someday!
Truck Guy99
Feb 23, 2014 02:28 PM
jg96powerstroker
Jan 29, 2011 02:36 PM
Tex1986
1997 - 2003 F150
Sep 8, 2009 08:48 PM
dannyboy7.3
39
Jul 15, 2008 05:36 PM
DMAN
Oct 28, 2007 09:21 PM
