Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Tools-Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana 30
Old 12-14-2012, 01:35 PM
Specialtools's Avatar
Specialtools
Specialtools is offline
Former Vendor
Thumbs up Tools-Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana 30
This set includes :
TKIT-1994-FMH/FLMH
501-025 Rear View Mirror Installer
412-098 Holding Fixture, Compressor Clutch
204-182 Remover, Ball Joint
303-474 Installer, Crankshaft Front Oil Seal 4.2L, 3.9L : F 150;Mustang;Freestar;Mark Lt ;Monterey : 2004-2008
307-309 Remover, Torque Converter Fluid Seal Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana 30;Sable;Milan ;Mountaineer;Grand Marquis 2004-2011
307-310 Remover, Lube Tube
307-311 Protector, Piston Seal
307-312 Air Test Plate, Transmission
307-314 Remover, Reverse Clutch/Planet
307-315 Installer, Lube Tube Fluid Seal
307-316 Remover/Installer, Front Clutch
307-317 Aligner, Output Shaft Fluid Seal
307-318 Remover, Stator Bearing
307-319 Protector, Piston Seal
307-320 Shim Selection Gauge
307-321 Shim Depth Gauge
307-322 Protector, Piston Seal
These Tools was moved after Ford dealership closure.
$ 125.00 or best offer- "No reasonable offer will be refused!"
raybx01@gmail.com or Please Call Ray at 512-845-4844
We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request.
I can ship Overnight or two day shipping. You decide, you are in control.( I do not ship overseas)
Specialtools
12-19-2012 12:57 PM
Quick Reply: Tools-Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana 30
