Rattling Noise during acceleration
I have a 01 5.4 with 210k. When I get on the gas and the rpms go above 3k, a chain like rattling noise happens. It sound like is coming from the back of the engine right by the firewall. The further the rmps go up the louder it gets. What could cause this noise. Will this effect the engine?
Thanks,
Ryan
Thanks,
Ryan
This might be the heat shield surrounding part of the exhaust system right under the drivers seat.
While cold check it for being loose, typically at the rear--the spot welds break and cause this same sort of rattle.
If this is is a large diameter worm drive steel clamp can be used to secure it once again.
HTH
HTH
HotWhlz85
05-20-2002 04:31 PM
