Front end
Old Nov 20, 2012 | 12:40 PM
omahaford's Avatar
omahaford
Front end
Trying to figure out what front axle is and if I can get an electronic locker for it. I have a 99 f250 4x4 diesel 4 door long bed solid front axle
thank in advance
Old Nov 20, 2012 | 12:48 PM
sammie0126's Avatar
sammie0126
thank in advance
It should be a Dana 60 - what is the tag number code on the differential housing cover? Should be a metal tag.
Old Nov 20, 2012 | 12:49 PM
duck fan's Avatar
duck fan
Because racetruck
Actually since its a 99 F250, it should be a Dana 50. Dana 60 was on later trucks and F350s
Old Nov 20, 2012 | 12:52 PM
sammie0126's Avatar
sammie0126
Yep you are right Duck Fan - OP correction Dana 50 - check the tag number to know for sure.
Old Nov 20, 2012 | 12:54 PM
VegasFordSD's Avatar
VegasFordSD
X2 I thought they made the switch in like 2002...
Old Nov 20, 2012 | 01:37 PM
omahaford's Avatar
omahaford
talking to ford and they dont know even with all the info on the tag
3.73 f81a cl top row
610892-1 bottom row
Old Nov 20, 2012 | 02:00 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You have a 50, and it should be stamped with a 50 somewhere on top of the bell housing.
Old Nov 20, 2012 | 03:04 PM
sammie0126's Avatar
sammie0126
610892-1 bottom row
From Dana website
50/229 1999 1/2-2000 F-250/350 SRW (4x4) 610892-1 Standard 3.73
http://www.google.com/url?sa=t&rct=j...2rPTqQ&cad=rja
Old Nov 20, 2012 | 05:42 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Using the charts Sammie provided a link to, I found that my 2001 Dana 50 is really from 2000. It is also not one of the D50's that is SUPPOSED to be on the Excursion for that 2000 lot of axles. It is, according to Dana, supposed to be on a F250/350 4x4 with ABS in the 2000 build year. Sooooo, Dana supplied the axles to Ford in blocks/lots (apparently), and Ford threw them on whatever they wanted (I'm thinking).
BrandonLamb
Feb 22, 2014 09:02 PM
kawkx500
Mar 21, 2011 04:09 AM
BCHauler
Sep 3, 2010 04:46 PM
cpd806
Oct 3, 2005 08:46 AM
Batoutahell
Jan 2, 2002 05:59 PM
