Just rebuilt m5r2 trans now there is a noise help.
Hello everyone I have a 1991 f-250 5.0 4x4 standard cab i just rebuilt the trans M5R2 all new bearings seals and synchros also new input shaft just got it all put back together and when the clutch pedal is up not pushed to floor there is a whinning noise higher rpm's faster the noise as soon as i push clutch pedal down the noise goes away the noise is there when ever the clutch pedal is up no matter if in neutral or and gear. I also put transfer case in neutral and the noise is still there any help would be great thank you all very much.
I suppose it could be either, but the noisy ones I've had have been quiet(er) when engaged. I've never had one that was bad out of the box though.
What about when you have it in 4th gear, is it still equally as noisy? My M5 is clearly most quiet when in 4th. Prior to my swapping in a new fork, 1-2-3 & 5 were noisy; they're still louder than 4th, but tolerable.
The noise seems to be the same in any gear. No clutch fork in this style T/O and slave is one assembly they are inserted over input shaft and bolted to front of trans inbetween bell housing and clutch assembly. I was also wondering I didnt install pilto bearing is that a posability? stupid me i should have installed one didnt even think about it.
F-250 restorer
04-03-2019 10:54 PM
reamer
21
02-08-2014 09:26 PM
Rosco71287
04-14-2013 01:00 PM
CAlex6977
11-23-2002 02:35 PM
