94 ranger fan clutch
I have a shop manual for 91s, and it shows a RH thread for the 4.0 liter. The 2.9 and 3.0 liter are LH. It's probably the same for 94s
Maybe you should look for a different set of fan tools. This looks like the same setup that I did on an old E150, and the 2 wrenches that I had worked great. It was on good and tight too -- especially since I was originally misinformed about the thread direction.
I rented mine from Big Wheel -- no longer around. However, you might look at someplace like Checkers. I don't know anything about the Autozone tools, but I'd check to see if there are better ones available.
ford2go
ford2go
The 1 7/8 wrench is for Super Duty Diesels. The size you need is 1 7/16" for the clutch and another one 3 1/4" to hold the four bolt heads going into the water pump pulley. If you can't get the 3 1/4" size, you can usually hold the pulley by placing a big screw driver between two bolts and holding against the direction you are turning the fan clutch.
Leeboy1962
35
07-21-2018 08:06 AM
fordka
09-17-2015 01:44 PM
jpcjguy
07-07-2010 12:03 PM
