New Owner Looking to drop 2"
I just bought a 2003 Excursion 7.3 EB and its and inch to tall to clear the underground parking where I work.
I run a Big Office building so I use the parking Lot as a heated Garage to work on my Vehicles and I have a premium reserved Parking spot that is 25' long and 10' high on P2 level unforchantly my truck will not clear an 8" water main by an inch to get to my spot so I was wondering how hard it would be to drop the back by 2" For now I am parking in the Loading Docks but I worry about it getting hit by delivery trucks
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
I don't have my Ex with me right now to look at it, so I don't know if this will work. Currently, is it the roof rack that will hit the pipe? If so, you can remove it.
Another "cheap" option (but would suck if you had to do it daily) is to let some air out of the tires, and have either a portable air tank or a 12v air compressor in the truck to air it back up after you passed the pipe on your way home.
Or buy some 205/70/14" tires/wheels and get some fuzzy dice on the rear view mirror.
As far as lowering the suspension...someone else would have to help with that.
If it's 4wd you might have issues finding a way to safely lower it, unless there is a lift on it, then you could return to stock height, but that still really wouldn't help. I only clear my 7' door by a couple inches. Another issue is apparently your parking garage isn't built to EMS spec. They would play hell getting a 9' Ambulance through there if needed, would be a shame for the fire marshall to find out and they have to fix it.
I'm In Canada we don't have Such Codes for Parking Garages
I did look at the axle and it has a (approximately) 6" Block between the axle and the Spring.
I found this online
Ground Force Suspension Ground Force Universal Suspension Block - JCWhitney
any advice on this?
thanks again
I found this online
any advice on this?
thanks again
I would consider just swapping out tires for now to a lower-profile tire. You can get a second set of rims fairly reasonable, and then drop to a 245x75x16 LR E or even a 225x75x16 LR E. These are common sizes, and if you have 265's or bigger dropping to the smaller tires will drop it pretty easy.... Just another option... though it will look a little funny, it is easier than some of the other options, and can be changed back alot easier too.
Garry
Garry
If you have a large block in the rear you may have a f350 block. Downsizing to the stock excursion block would lose some height. When you measure the rear can you take a picture and post it.
We were in Boston a few weeks ago and most garages there had 6'8" or less, the one we found that we could fit in cost $33 for a day, they wouldn't even let me park in outside spots cause they said it was too big heh heh.
So if I took out the 2 1/4" spacers out my front and back would be the same height (now the front is 23" from center of hub to truck and the back is 25")
Can Any one tell me why it would be a bad Idea to remove it
Thanks
